Plaster Wall - Cutting Out An Access Hole, But How To Replace It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-05-2008, 11:05 AM   #1
DIY are my initials
Plaster wall - cutting out an access hole, but how to replace it?
I am re-plumbing my bathroom, I must go through the plaster wall behind to replace the pipes. What would be the most economical method of replacing this section? Is there a good way to install an access panel that looks good?
I have a mini circular saw to cut this baby out, i'm guessing I should use a blade that has a lot of teeth per inch.
Thanks for the help!
Steelmesh is offline   Reply With Quote
Old 11-05-2008, 11:36 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Discussion here with pictures: Wall access tips?
- Build Well -
Old 11-05-2008, 11:50 AM   #3
Cut to the middle point of the studs on either side. Then make the top cuts to remove the piece.
Do your plumbing.
Then get a piece of sheetrock and put in to cover up the access hole.
Get some drywall mud and seal up the edges. Sand as necessary.
Get one of those cans of texture. They are expensive. On a scrap piece of drywall practice till you get the texture the same as the existing plaster.
Then do the real thing.
Paint to match and you are done.
USE A MASK WHEN YOU CUT OUT THE PLASTER. That is toxic stuff to your lungs when airborne.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-05-2008, 02:25 PM   #4
DIY are my initials
Thanks gentlemen for the advice!
Old 11-05-2008, 04:09 PM   #5
What sort of base does your plastered wall have?
Ai my house a plaster board was nailed on the studs, then a rough coat of plaster, followed by a smoother finish coat.
The total thickness is about 3/4".
When I had to fill a cut-out hole, I had to fasten 1/4" strips of wood to the studs to build it out for the 1/2" drywall patch.
Old 11-05-2008, 04:12 PM   #6
Electrician
OR, if you dont want to replaster just buy yourself a access door, they can be painted and may work just fine for you.
chris75 is offline   Reply With Quote
Old 11-07-2008, 06:49 AM   #7
DIY are my initials
I cut open the wall yesterday. It is actually "wood" lath, but the lath isnnt really wood. They are like plaster planks about 1/2"x4". I've got to finish this plumbing job so I can finally move in...I will check out the HD for access panels
Old 11-07-2008, 08:48 AM   #8
Electrician
They sell them at HD, they even have a 1hr fire rating, I use them quite often, although I generally buy one before I cut the hole.
Old 11-07-2008, 09:40 AM   #9
DIY are my initials
Doh! Learning from others mistakes is key, so its quite possible the purpose of my life is to help others learn
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 06:14 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
How do I drill the hole in the wall if I don't know location of electrical wire popkadurak Remodeling 10 06-16-2006 10:06 AM
