Plaster To Drywall Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 03:41 PM   #1
Post
Plaster to Drywall Repair
I am putting in a new half-bath and had to remove one wall (plaster) to run new plumbing. I have hung the drwall into exposed studs, but have about two inch gaps between drywall and remaining plaster. The plaster edges of the remaining wall are rough (from the demo), and was wondering of the best way to fill the gaps and make the corner look best.
Any advice is much appreciated.
seifribk is offline   Reply With Quote
Old 11-10-2011, 05:18 PM   #2
Rewards Points: 5,336
The drywall should butt up to the plaster. A 2" gap is not going to be filled with anything.
A photo will help.
Ron
B. Franklin 1759
Old 11-10-2011, 07:33 PM   #3
Why the gap? is the room just that much larger than a sheet of drywall? Or is it a lack of studs/backers to attach the drywall to? Either way, you will need to fill that 2" in with drywall. If you don't have studs to attach it to, you can put in some blocking perpendicular to the studs, enough that you can get a screw in at least every 12 inches.
As Ron said, a picture would help make any suggestions more useful.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 11-10-2011, 07:57 PM   #4
joed's Avatar
Rewards Points: 11,988
Trim the plaster as clean/straight as you can and fill the gap with drywall. Then tape and mud it just like any other drywall joint. The mud will stick just fine to the plaster wall.
Tags
drywall , plaster , remodel
Removing sag from drywall repair billt23 Drywall & Plaster 4 03-25-2011 10:49 PM
Plaster Wall Repair lierman44 Drywall & Plaster 4 03-09-2011 10:12 PM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 03:20 PM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 03:13 PM
Joining drywall and plaster pete1972 General DIY Discussions 5 10-28-2006 06:08 PM
