Plaster Composition Vs Sheetrock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 10:31 PM   #1
Question
plaster composition Vs sheetrock
I recently removed part of the lathe & plaster wall in my kitchen. The plaster removed is grey & very heavy. Does anyone know what it is made from? (chemical composition) Could it contain cement or asbestos? The house is very old - knob & tube wiring. If the plaster is calcium sulfate like in patching plaster, I think I can use it to break up the horrible clay soil around the house.
reny is offline   Reply With Quote
Old 04-16-2009, 03:30 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by reny View Post
.....Could it contain cement or asbestos?...
Get it tested or at least get test kit'
http://www.prolabinc.com/products.asp?kit=asbestos
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-16-2009, 06:42 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Asbestos was sometimes used as a binder in plaster. you definintely want to get it tested before you go tearing it out. And absolutely do not till it into your lawn if it's got asbestos in it. You'd be breathing asbestos fibers every time you'd mow the lawn. Not good.
Old 04-29-2009, 07:59 PM   #4
Thanks for the info & site. I'll follow up.
reny
WAINSCOTTING With BEAD BOARD Nathan Carpentry 29 02-24-2013 03:42 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 10:15 PM
Ceiling fun --- New sheetrock meets old plaster! TivoTron Remodeling 8 02-13-2008 03:54 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
