Old 06-30-2008, 04:08 PM   #1
Question
planing uneven beam bottoms for ceiling sheetrock
is this a common practice for older homes where some beams may have subsided slightly ? my house is 100 yrs old. i definitely have some uneven beam bottoms, no more than 1/4' between adjacent beams.
Old 06-30-2008, 05:00 PM   #2
gravity always wins
Lumber was pretty good back in that day, but finishing techniques weren't always the best. It's not uncommon to see framing lumber in older homes with a lot of variation. 1/4" isn't too bad. You can see almost that much today.
Old 06-30-2008, 05:14 PM   #3
Question
thanks. so, should i resort to the proposed technique ?
Old 06-30-2008, 05:16 PM   #4
Moderator
Termite's Avatar
I would not plane them. It'll be more work than it is worth. I'd suggest adding strips of lumber to the side of them or perpindicular to them to fur the entire ceiling down just a little bit to make up for the variations. Pretty easy to do with a laser or a long straight edge.
Old 06-30-2008, 05:17 PM   #5
RippySkippy's Avatar
I wouldn't....that's a lot of work for a relatively small gain. I'd use sheet rock shims in the area above the lowest plane. Once you finish, most likely you'll never see it.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-30-2008, 05:18 PM   #6
Moderator
Termite's Avatar
Me and RippySkippy are thinking with the same brain. He said it better though.
Old 06-30-2008, 05:19 PM   #7
okay - i just wanted to add a planer to my toy kit and was looking for an excuse ...
Old 07-23-2008, 04:17 PM   #8
Drywall contractor
I think I'd have to find a better excuse than to have to use it overhead on a bunch of semi-petrified (probably oak) ceiling joists!! OH my aching shoulders!! I'd bet there's a couple of doors that could use a shave though.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
Basement Beam and Columns..... shamrock33 Building & Construction 1 03-19-2008 06:03 PM
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 11:37 PM
