Placing New Window In Sliding Glass Door Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 11:17 AM   #1
placing new window in sliding glass door space
How do I put a window in a sliding glass door opening that is installed at ground level and floods when there is heavy rain?
The room in question is built in an old carport. My goal is to stop the flooding coming under the sliding glass door and make the bedroom more secure at night when I would like to have a window rather than a door open.
Would a brick or cinder block wall built on top of the existing cement slab resolve my water problem? It might be more cost effective to do 3 rows of brick and then use Hardy plank on top of that as there are already 2 rows of brick at the foundation that could be extended across the opening. What kind of membrane would be used as flashing for the small knee wall and how is it installed?
I do not think footings are required in that 71 inch space? I plan to put the wall to support the window on the cement that is now supporting the existing sliding glass door. The 1971 cinder block Kure Beach, N.C. house is located 2 blocks from the ocean. It has two rows of brick at the foundation of the cinder block that I could continue across the 71 inches.
Any thoughts are most welcome.
L. Loving
L. Loving is offline   Reply With Quote
Old 10-25-2012, 12:33 PM   #2
Rewards Points: 13,950
On the right track. Two rows of block fill some with concrete so you can set foundation bolts in the voids to hold the wall in place. Sill seal then the bottom plate and just frame in the wall to fit the window.
Sliding Window Removal Help AZSun Windows and Doors 4 09-07-2011 08:26 PM
Sliding Glass Kitchen Window dnika25 Windows and Doors 1 07-25-2011 08:57 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 11:22 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 08:49 PM
