Placement Of A Fish Tank - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 06:39 PM   #1
placement of a fish tank
I want to put my 90 gal fish tank in a new location. The problem is it will run with the floor joists. The tank is approx 1000 lbs. The joists are 2x8, 16"c, and span 12 feet. I don't have a bsmt just a crawl space. Do I need extra supports?
steve0825 is offline   Reply With Quote
Old 12-29-2008, 09:37 PM   #2
if it were me I would check the supports in the crawl space but I would say no you do not need extra. The weight of the tank ,water,and extra should come to about 800lbs and that wont be a problem especally if the tank crosses at least two joist
clasact is offline   Reply With Quote
Old 12-29-2008, 09:48 PM   #3
What kind of stand do you have? The ones with four points of contact are rougher on the floor obviously. The ones that touch the floor all along the base will spread out the weight very well too. Plywood under the floor will also spread out the weight well.
A buddy of mine lives in the third floor apartment (1 bedroom) and has fish tanks in every room. His "fish" room has tanks along every wall including a few 50 and 60 gallon tanks stacked above each other. No problems with the flooring supports, but every once in a while the tenants below complain when he changes the water and they see water dripping from the ceiling hahaha. He has at least 30 tanks in his tiny apartment. The heat and humidity are nuts, but his tanks are all very nice.
What will you be keeping in your tank?
jonathan03 is offline   Reply With Quote
Old 12-29-2008, 11:19 PM   #4
Thanks for the quick reply....
I have a stand that has a solid bottom... 52" x 20"
I can't be 100% certain that it is resting on two joists. It may be only on one. Would that still support the weight? What is the worst that could happen?
As for fish........I am looking at either rays, an arrowana, or both......
Old 12-30-2008, 05:35 AM   #5
well if it will be resting on just one it could start to bow under the constaint weight but at 52inches long it should cover two which will distribute the weight better and being a solid bottem will help also.If it is only crossing one I would get in that crawl space and put in a few braces and blocking under the joist.I am sure your not going to be moveing this on a reg bases and that weight over time could cause your flooring to bow on you.It is alwasys better to do some prevent maint. now then have to worry about fixing a mess later
Old 12-30-2008, 10:05 AM   #6
If it is spread across at least two joists then you may be OK provided that you don't already have other heavy items on the same joints such as appliances...
duckdown is offline   Reply With Quote
Fish tank plumbing problems.. Raibaru Plumbing 2 12-15-2009 02:13 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
GFCI for a fish tank? fw2007 Electrical 6 10-05-2007 12:06 PM
