Pipe In Garage Leaking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 09:35 PM   #1
pipe in garage leaking
what is it
iris casteel is offline   Reply With Quote
Old 07-15-2012, 09:35 PM   #2
not sure what this pipe is for
Old 07-15-2012, 09:58 PM   #3
Metal Roofing
Rewards Points: 600
It's that one right there...see it.
Seriously, we need more info but most of all a pitcure of the pipe.
AndyWRS is offline   Reply With Quote
The Following 2 Users Say Thank You to AndyWRS For This Useful Post:
Evstarr (07-16-2012), mae-ling (07-15-2012)
Old 07-16-2012, 10:55 AM   #4
pipe in garage
its a pvc pipe that is coming out of the roof in my garage my husband thinks its link to the ac but my AC is on the side of my house and the pipe has been leaking for a few days when we run the AC and it never has done this before so we are concerned about it
Old 07-16-2012, 11:03 AM   #5
Rewards Points: 14,300
Your there were not, follow it to see what it's attched to.
If it's the A/C condinsate drin it will be attched to the pan under the unit.
Old 07-16-2012, 11:25 AM   #6
Sorry Joe! I haven't had enough coffee yet and that gave me a headache.
? In case you didn't get that?
You're there, we're not. Follow it to see what it's attached to.
If it is the ac condensate drain, it will be attached to the pan under the unit.
Now you stated that the ac is on the side of the house. Where is the air handler? If not in attic, then we keep looking to see where it goes. (and by we, I mean you).
You could help us help you by giving at least a shred of useful description of your situation.
What size is the pipe? If its 4 inch PVC, then it's not ac! if it is the drain for the pan, it's plugged and may need to be blown out.
Post a pic please!
Evstarr is offline   Reply With Quote
Old 07-16-2012, 11:41 AM   #7
You guys don't really like giving detailed information, do you
garethcooper9 is offline   Reply With Quote
Old 07-16-2012, 11:54 AM   #8
"its a pvc pipe that is coming out of the roof in my garage my husband thinks its link to the ac"
It is very likely that is hooked to the AC, most systems have the air handler in the attic. Generally this would the secondary "backup" drain line. You put these in a very obvious place so when water comes out it is seen. The reason it would not drain before is you primary drain line dumps the water down the house drains. When it gets plugged it overflows into this secondary line.
bill01 is offline   Reply With Quote
Old 07-16-2012, 03:38 PM   #9
Metal Roofing
Rewards Points: 600
I was dead right, what are you talking about.
Vent Pipe in Attic Leaking - Advice Rick78 Plumbing 10 07-29-2011 07:02 AM
New sewer pipe for new bath in detached garage gante Plumbing 1 04-10-2011 06:14 AM
Leaking vent pipe? emylime Roofing/Siding 12 04-28-2010 01:47 PM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 07:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
