Pink Insulation Has Darkening Areas - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 01:48 PM   #1
Rewards Points: 41
pink insulation has darkening areas
Blowing in a new layer of insulation, and in prepping have found some of the older pink rolls to have areas where the pink insulation is darkening. Sort of a charcoal/blackish color - usually near areas where air can come up thru the ceiling (drywall seams, near top plates).Should I replace/pull out this insulation before blowing another layer over it?
kelley4180 is offline   Reply With Quote
Old 01-29-2010, 04:16 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
that is an indication that air is passing thru the fiberglass,and dirt is being filtered out by the glass fibers
i would pull out the dirty insulation and air seal any penetrations using spray foam or caulk
should you reuse the old? depends on how dirty it is i guess but you want to make sure that there is no mold on it
Tom Struble is offline   Reply With Quote
Old 01-29-2010, 04:41 PM   #3
that is why you should be using vapor barrier and seam tape so no air flows though.
wnabcptrNH is offline   Reply With Quote
Old 01-29-2010, 05:33 PM   #4
Rewards Points: 41
Is there an easy way to tell dirt from mold?
Old 01-29-2010, 05:36 PM   #5
Whats it on drywall?
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Can foamboard insulation be used in living areas, vaulted ceiling? Spud Building & Construction 14 10-13-2009 01:48 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
