04-21-2010, 06:39 PM
#1
piers - concrete curing/framing
just finishing pouring 5 piers - 4' deep 12' diameter sonnotubes at about 5pm EST.
the anchor bolts are in and the stuff is already setting up nicely.
the post anchors are the new simpson really heavy gauge steel (about 1/4" thick) anti uplift style.
it looks like the nut needs to be tightened on the bolt before putting the pad in place and dropping the post in.
wondering if by tomorrow morning i can start framing on these piers, and just lightly tighten the nuts down and away we go?
what do you guys think?
the bags said walking-on time 12 hours. but does this mean the bolts can handle a bit of strain?
thanks.
04-21-2010, 07:49 PM
#2
Moderator
What are you framing?
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
04-21-2010, 08:15 PM
#3
Old School
When I saw the question, I didn't think much about it. But when I saw your name, I broke out laughing.
The man who is anal about precision and perfection in his rafter cuts wants to cut time he knows very well concrete needs to cure for strength by putting the most vital bolts in the whole project under stress within about 16 hours of pouring?
Look it up. Go read the time charts for strength development in concrete curing.  Got to say you sure caught me off guard with this post.
Willie T
04-21-2010, 08:38 PM
#4
Xtreme DIY'r
I waited several days before I did anything with mine
04-21-2010, 09:15 PM
#5
Originally Posted by Willie T
When I saw the question, I didn't think much about it. But when I saw you name, I broke out laughing.
willie, i don't know what your problem is. first of all, i'm not anal about rafter cuts, i simply wanted to understand the math.
and this post was a simple question. the bag tells me i can walk on it in 12 hours, why not frame on it in 16 hours?
04-21-2010, 09:50 PM
#6
Xtreme DIY'r
From what I have read on several sites 3-7 days
2/3 of strength achieved in 7 days ?
..they linked to sites, but links were not working
Min seems to indicate 3 days. 7 days preferred
04-21-2010, 09:51 PM
#7
Moderator
If your building a house, it's a 28 day wait in my neck of the woods.
The Following User Says Thank You to kwikfishron For This Useful Post:
04-21-2010, 11:23 PM
#8
Civil Engineer
Standard concrete achieves design strength in 28 days, and continues to strengthen for many years after that. Typically the concrete achieves at least 50 percent of design strength after 3 days, and 75 percent of design strength after 7 days. This depends on the mix, what additives were used, and placement conditions.
If you plan to tighten the bolt down fully because you are going to cover it over and will not have access to it later, you need to wait at least three days, or your risk cracking the concrete when you tension the bolt. If you just need to lightly attach it, and can torque it to design specs later, you could lightly tension after 36 hours, and tighten to spec after 3 days.
04-21-2010, 11:39 PM
#9
thanks guys.
to answer kwikfisher:
just building a small porch on these things- 2X6 double rim joist, 2X6 joists.
going to hold off tomorrow and do a gentle torque on friday morning and begin framing.
i might frame the rim joist on temp supports, then slide the posts in later. i don't like doing things this way, though.
thanks again.
04-23-2010, 09:24 AM
#10
since no one knows when conc finally's cured & we can measure time, that's why we test at 24hrs, 7d, & 28d.
you did use ' L ' or ' J ' bolts, right ? IF it were mine, i'd finger-tighten now & tighten more in 3d as dan post'd,,, it is for uplift not suspension,,, gravity'll keep anything like this in place !
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
