Old 11-02-2008, 11:55 PM   #1
Pier Spacing
Pier Spacing.
Click HERE for my drawing
As some of you may know, I plan on rebuilding a porch that I hired a contractor to build for me.
I am building a 31' 8" x 10 foot porch on the front of my house.
2x10 PT southern pine joists, beam and ledger
5/4x6 cedar decking boards running perpendicular to the house
This may seem like a very dumb question to some of you, but I have somewhat of an issue trying to figure out where to put the posts without blocking the view of the windows and still having a uniform look on the spacing between posts for the guard rails. I have posted a rough Visio drawing (yes, it is rough, Im just a diy'er ). I'm just looking for ideas to make this look appealing and uniform. The 6x6 posts that are currently drawn on there should stay. I need help in the placement of the other posts.
Thanks in advance for the help.
my5sons is offline   Reply With Quote
Old 11-03-2008, 02:21 PM   #2
MetalArchitect
Pier Spacing
What kind of roof are you doing...a shed or hip all the way across...is there a gable over the entrance?
I might say up the header to a double 2X12 and throw one support in the middle...it depend on the roof configuration
Rkeytek is offline   Reply With Quote
Old 11-03-2008, 02:48 PM   #3
Pier Spacing
This is a gable roof. I actually need help with the post placement locations under the deck too.
Old 11-03-2008, 03:05 PM   #4
MetalArchitect
Pier Spacing
I don't think you'll be able to frame the windows perfectly and keep an even spacing on your posts...the most important thing is the spacing, IMO.
Your not going to see the house on a perfect straight on shot, so from different viewing points a post will almost always be in a window view. try laying out (2) post evenly between the end post and the one by the entrance (spaced about 9 feet apart. You'll get the most uniformed look and only have a post in a small portion of the window ( when looking at it dead on)
Outside Baluster Spacing DangerMouse Building & Construction 65 05-18-2009 02:11 PM
Dek Building- pier to post connection- necessary? k man Building & Construction 4 09-28-2008 06:21 PM
Conduit Spacing / Separation smitty286 Electrical 3 04-08-2008 11:11 AM
Baluster Spacing chicago woodman Remodeling 4 12-08-2007 12:19 PM
concrete pier cibula11 Building & Construction 5 06-16-2007 10:11 AM
