Pier And Beam Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2013, 03:59 PM   #1
Post
pier and beam foundation
im wanting to build a 28ft by 56 ft home. i want to use a pier and beam foundation using cinder blocks. how do i know what sizes and how many of the things i need to get started? i need to know from how many cinder blocks to how big and how many beams and piers. and all the little things i need to finish foundation. help?
becka1594 is offline   Reply With Quote
Old 04-26-2013, 04:53 PM   #2
Rewards Points: 502
That would depend on the loads you are carrying (1-storey, 2-storey);
the height, size and spacing of the block piers; the ground-bearing capacity etc -so many unknowns.
tony.g is offline   Reply With Quote
Old 04-26-2013, 05:43 PM   #3
Arrow
it will be a 1 story, and with an average height, which is like 8ft? i think. but anyways, how spaced out would the cinder blocks have to be? and how big of beams would i need, and how many?
Old 04-26-2013, 08:52 PM   #4
Msradell's Avatar
Rewards Points: 210
Nobody here will be able to give you an answer to your questions. In the 1st place, we don't know anything about where this will be built, the soil conditions in the area, nor do we know the building codes in your area. Even if these were known, you shouldn't trust any information this critical to a new home on any information you receive from the Internet. You need to contact a local engineer, architect, or at least code official for their input.
Msradell is offline   Reply With Quote
Old 04-26-2013, 09:14 PM   #5
joed's Avatar
Rewards Points: 12,852
How far apart the posts are depends on the size and material of the beams. The size of the beams depends on the loads and the spacing of the posts. You need an engineer or an architect to determine the optimal spacing, beam size and cost depending on the building.
Old 04-26-2013, 09:23 PM   #6
Roofmaster
Rewards Points: 2,210
They make these things called plans................... Blueprints? Architectural? Structural? Mechanical? Electrical?
Little house on the prairie don't cut it anymore, unfortunately.
Read Below:
Tags
cinder blocks , foundation , home building
Cinder block pier and wooden beam cabin foundation I need help Dannyjsj1 Building & Construction 13 03-06-2013 03:18 PM
Pier and Beam Foundation ms66cadillac Building & Construction 10 01-13-2011 06:24 PM
Installing wonderboard on pier and beam foundation Harrington Flooring 3 12-01-2010 12:29 PM
Pier and Beam foundation, 1925 house NewOldHomeOwner Building & Construction 8 01-30-2010 11:51 AM
Pier & beam foundation JustEnuf Carpentry 2 08-02-2009 07:58 PM
