Pier And Beam Construction For A 40' X 40' Add On Room. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 09:00 PM   #1
Pier and Beam construction for a 40' x 40' add on room.
We have two mobile homes 40' apart we would like to connect them with a 40' x 40' room. Building the room on a pier and beam system. Where can we get plans for such a project?
JaninePT is offline   Reply With Quote
Old 03-12-2012, 09:50 PM   #2
Rewards Points: 528
you need an architect, designer or engineer, this is not a standard project, sorry.
framer52 is offline   Reply With Quote
Old 03-13-2012, 10:31 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated - hire an architect. You will need precise plans to submit to your local building dept. as well.
- Build Well -
Old 03-13-2012, 10:43 AM   #4
Rewards Points: 13,750
If you have the money to do something like this I think I would get rid of the mobil homes and just build a real house. Keep in mind I have owned and lived in mobil homes for the first 18 years of my life, so it's not meant to be a put down.
Doing what your suggesting will not increase the value, and would be really hard to even get a bank to lend money for it if someone did want to buy it. Going to be really hard to keep the intersecting roof lines from leaking because as a general rule mobile homes are so under built there barly able to support what's on there now.
AndyGump (03-13-2012)
Pier and Beam construction ??? Clutchcargo Building & Construction 4 03-11-2012 09:13 AM
pier and beam construction axcess hole sn604s Building & Construction 13 01-22-2012 09:57 AM
Adding posts and beam to floor for aquarium Vincer Building & Construction 4 03-23-2011 02:47 PM
Pier & beam foundation JustEnuf Carpentry 2 08-02-2009 07:58 PM
pier and beam coverings? crafty Flooring 1 10-25-2005 08:45 PM
