Picking A Foundation For Shed/simple Workshop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 12:47 PM   #1
Picking a foundation for shed/simple workshop
I'm building a shed/simple workshop (12'x16' or 16'x16') this spring, (I am in New England). The sight is slightly sloped and does not have a problem with standing water. We have no zoning rules here so that is not an issue. I am struggling to pick a foundation. I'm deciding between these basic options:
1. Concrete blocks at the corners and in the middle of the spans.
2. Concrete piers sunk ~4' in the ground using sonotubes and maybe bigfoot forms
3. Concrete pad
Option #1 has a lot of appeal due to its cost and simplicity. (I have an old outbuilding that was built on stacked stone and seems to have withstood the test of time.) Option #2 seems more rugged than #1, but is the extra effort worth it? Option #3 seems by far the most robust, but again is the extra effort worth it?
The building will be used mostly for storage and occassionally simple carpentry projects.
Thanks for any advice.
Corey in NE is offline   Reply With Quote
Old 01-31-2010, 01:14 PM   #2
My pool cabana has a pad on the pre-existing part
I opted to pour a perimeter "foundation" 12" deep
Then I'm filling the area & putting down pavers
Main reason was to be able to pull the pavers up to access the pipes to & from the filter & pump
And I did not want critters using the space under a wood floor as a home
Old 01-31-2010, 02:03 PM   #3
Rewards Points: 1,016
I would suggest to put in on a concrete pad - and make the building as large as is reasonable while you are doing it. This makes for the best use experience, longest lasting, and most value add to the property.
Old 01-31-2010, 02:11 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,078
Ayuh,... I'd do a floating slab,... 12" deep x 12" wide footers, to a 4" slab...
That way, frost shouldn't be an issue,+ you'll have a "Nice" floor surface to work or store on...
Old 02-01-2010, 11:19 AM   #5
Does a floating slab mean it is not connected to the footers? I've read about putting in slabs and it shows how to do the footers but it always seems to be one piece.
Old 02-01-2010, 12:22 PM   #6
jlhaslip's Avatar
Rewards Points: 1,572
A floating slab usually has a thicken edge which acts as a footing to carry the building's weight.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-01-2010, 02:02 PM   #7
http://home.howstuffworks.com/home-i...air/house4.htm
A nice diagram there on how a floating slab works.
cellophane is offline   Reply With Quote
Old 02-01-2010, 03:59 PM   #8
Rewards Points: 346
If you do a floating pad be sure to put a vapor barrier under the slab. If you don't you may have problems with rusting tools. I would prefer a wood frame floor for a shop if you will be using it daily. That said, the slab would be less maintenance and less of a problem with varmints.
Rege
RegeSullivan is offline   Reply With Quote
Old 02-01-2010, 04:46 PM   #9
I have built many sheds and storage buildings for myself and relatives.
Just level off the ground and put in a 4" slab on grade , before the concrete starts to cure put hold down bolts around the perimeter, and be sure to use pressure treated lumber for your bottom plates.
Don't worry about frost if you are not connecting the shed to an existing building it will float by itself, " Keep it Simple"
SULTINI is offline   Reply With Quote
Old 02-01-2010, 09:49 PM   #10
Thanks for all of the good advice. It seem the consensus is to go with a concrete pad with footers. We have plenty of critters here so that would be a big concern if I built on blocks.
Now since the site is on a slope (unfortunately I don't know the grade), what is the best approach? Do I have to excavate the uphill side to make it level with the downhill side or can I do a sort of wedge to save myself some exacating?
Old 02-01-2010, 11:06 PM   #11
I would investigate to do a stem wall. You need to understand the grade to see how high the stem wall needs to be.
Here is a relavent thread:
Concrete Footings for a Detached Garage???
Old 02-02-2010, 12:32 AM   #12
jlhaslip's Avatar
You could add some fill to the low end and compact the bejeeses out of it.
If you do that, consider that the weight from the slab will require the dirt to be installed in 8" 'lifts' and compaction applied at each level.
Use good clean fill, not the topsoil or what you excavate for the slab. Gravel or road crush would be good.
I used 22 loads of pit run to level off my 24 x 26 shop and a 5 ft vibratory packer. I had to come up 6 feet at the back end and have a 4 ft wide walkway around the shop. The gravel also needs to slope away at its 'angle of repose, which means however it wants... The force of the slab will travel down at a 45 degree angle, and the gravel needs to placed and compacted so that the force is travelling along that slope line.
Do you need/want a picture?
Old 02-02-2010, 01:11 PM   #13
No zoning codes! Sounds like heaven. Do you mind if I ask where you are? I would love to be able to build a cottage without dealing with the zoning man.
bmancanfly is offline   Reply With Quote
Old 02-02-2010, 03:41 PM   #14
ever consider a pole barn type of construction? cheap and easy to build. can either have concrete slab on a level site or on a slope you can frame the floor with wood joist and decking which keeps the moisture at bay. wood floor is 1/4 the cost of concrete/finishing.
minidriver8 is offline   Reply With Quote
Old 02-03-2010, 11:07 AM   #15
This covers a few people's comments:
"No zoning codes! Sounds like heaven. Do you mind if I ask where you are? I would love to be able to build a cottage without dealing with the zoning man."
I live in a small town (< 1000 people) in Orange County, Vermont. The only real town zoning/permitting we have is when people put in driveways since those connect to roads.
"ever consider a pole barn type of construction? cheap and easy to build. can either have concrete slab on a level site or on a slope you can frame the floor with wood joist and decking which keeps the moisture at bay. wood floor is 1/4 the cost of concrete/finishing."
This was my original plan and I even bought a book on it and actually read it. I got bogged down a bit in the load calculations (partially me over thinking it, partially the book's poor explanation). One thing I didn't understand was if a concrete slab is used, how is that different than traditional construction? The framing and such seemed to be the same.
"You could add some fill to the low end and compact the bejeeses out of it. If you do that, consider that the weight from the slab will require the dirt to be installed in 8" 'lifts' and compaction applied at each level.
Do you need/want a picture?"
I think I can picture what you are saying and it makes sense.
I did a rough check of my yard's slope (there's snow on the ground so it was very rough), and it seems to be well below 5 degrees. For the size building I am thinking of, this puts the extra excavating on the uphill side at less than 1 ft.
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 05:34 PM
mulch against foundation??? fabian Landscaping & Lawn Care 2 05-08-2009 09:38 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
