Old 04-11-2007, 10:48 PM   #1
photos of foundation replacement
So guys I got the foundation job goin...
My brother-in-law, who conveniently happens to be a licensed contractor took on the job for me, and in three days between three guys, had the house dug up, supported, and the block knocked out and gone. Then, 6 Amish guys (two of 'em couldn't have been but 14) drove in from 2-hours away and laid all the brick in one day (today). I haven't even seen the final product yet, I'm stuck at work all night.
I have a new found respect for anyone that lays brick, or does brick demo for that matter... some of the hardest work around as far as I'm concerned!
elementx440 is offline   Reply With Quote
Old 04-12-2007, 09:15 AM   #2
concretemasonry's Avatar
Any reinforcement in the walls?
Did you do anything for draintile and sump yet?
concretemasonry is offline   Reply With Quote
Old 04-12-2007, 03:27 PM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
What did ya do that for?
Brik is offline   Reply With Quote
Old 04-12-2007, 03:38 PM   #4
Brik -
See the previous post on "bowing walls".
A distaster that may be in the process of being recreated. It could be a flip.
Old 04-12-2007, 04:35 PM   #5
that sounds pretty mean-spirited, no its not a flip
the drainage/backfill is in the works.
Old 04-12-2007, 06:29 PM   #6
How about the reinforcement in the wall?
Old 04-12-2007, 10:01 PM   #7
Those are block, not brick, and if they did not use reinforcing, both vertical and horizontal, you may well have only a temporary solution to the problem.
Tscarborough is offline   Reply With Quote
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 07:28 PM
replacement of old foundation lmeyers Building & Construction 4 10-12-2006 12:36 PM
re-enforcing foundation - southern cal jhb Building & Construction 1 10-02-2006 01:15 AM
