-   -   perplexing soffit corner (http://www.diychatroom.com/f19/perplexing-soffit-corner-30858/)
DangerMouse 10-29-2008 12:57 PM
1 Attachment(s)
how would you guys go about finishing up this soffit end? do i need a wedge shaped triangle of soffit supported at the end somehow? or should i do it like i did in the background shed when i do the siding? i thought that looked strange, but hey, it's just a shed and no soffits either... the next f-channel to go up to the peak will be about four inches higher than the one there already, leaving me a big gap to deal with. any pics how someone else has handled this would be appreciated. i'm confused... but what else is new?
tnkz!
DM
my5sons 10-29-2008 01:08 PM
This should help. I had the same question months ago.
http://www.popularmechanics.com/how_...c/1276126.html
DangerMouse 10-29-2008 01:34 PM
that did not help. it only showed how to do it if the soffit is slanted, not flat like mine. but thank you for the effort! =o) how's YOUR project going?
DM
buletbob 10-29-2008 01:45 PM
get your self a 2x8 or 2x10 cut it about 30" long. put it against the bottom of the rafter against the fascia board. take a level and level a horizontal line from the fascia back to the house. when your about 4" past the house corner make a plumb mark up. cut these two marks and install with nails and a block back towards the house. this would be called a pork chop.BOB
DangerMouse 10-29-2008 01:57 PM
having a hard time imagining what you mean bob, you got a pic or two? (i KNEW it had to be called SOMEthing!)
DM
buletbob 10-29-2008 02:00 PM
I tried sending the picture but wont down load, I'll try photo bucket. BOB
buletbob 10-29-2008 02:14 PM
I hope this helps BOBhttp://www.sweethaven02.com/BldgCons...02/fig1011.jpg
DangerMouse 10-29-2008 02:21 PM
ok, mine is the first one.... what do i use to cover the exposed wood when done? vinyl or alum.?
DM
buletbob 10-29-2008 02:25 PM
Bend alum.
