Old 03-23-2010, 12:28 PM   #1
Pern value of 8 inches of open cell foam
How do you calculate the perm value for a given thickness of open cell foam?
I found Open Cell spray foam has a "perm ratings of approximately 16 per 3 inches thickness (up to 30-35 perms at one inch)"
What would be the perm value for 8 inches? I'm trying to find out if 8 inches of open cell foam would be better then 3 inches of closed cell foam for a vapor retarder.
millertimeny is offline   Reply With Quote
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 06:02 PM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 05:04 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
conflicting spray foam insulation warnings yogi Building & Construction 8 10-01-2009 11:24 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
