Permitting A Basement. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 11:34 PM   #1
Permitting a basement.
What are the pros and cons to permitting your basement as you finish it??
Kjm25bball is offline   Reply With Quote
Old 05-18-2011, 05:30 AM   #2
DIY staff
Rewards Points: 7,174
You remove the risk of having to tear it all out if you are caught.
Old 05-18-2011, 05:53 AM   #3
What he said, but not all localities require a permit for a basement refinish. They generally do, since it increases the property value, and it is a gument revenue thing. Check local code.
Something to consider, codes generally require an alternate exit route if none is present. That means an egress window or another door.
The Following User Says Thank You to Just Bill For This Useful Post:
oh'mike (05-18-2011)
Old 05-18-2011, 08:25 AM   #4
Rewards Points: 5,336
I had a customer who finished his basement when he moved into his house in NYC in 1981. The Building Dept came knocking on his door in 2002 and told him they had a report of work(unpermitted) going on in his house. At this point he wasn't and let them in to look around.
They found the basement finished with a bedroom(no egress window) a full bath and a beauty parlor room.
It cost him $8600. to rectify the issues, get permits and inspections.
I've gone there at least 3 times to track down bad wiring where shorts in the boxes melted the wire insulation and 2 outlets and 1 TV plug.
The fact the house hasn't burned down due to bad wiring is amazing.
That's why you get permits, to have the work inspected to make sure you don't find yourself on the front lawn, in your jammies, in the middle of the night watching the house burn to the ground.
Ron
Old 05-18-2011, 08:46 AM   #5
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 822
Also if you go to sell eventually, it becomes a quick and easy way for the buyer to negotiate down, because the city won't have that square footage accounted for as finished space. You make it easy for a buyer to say "not only can't you list this as finished space, but now you have to disclose it that you know it wasn't permitted." Strong negotiating point just to give away like that. I bought a house a few years ago and got a ton of money knocked off the sell price, because an addition didn't have a permit. And the guy buying my old house tried pulling that on me, but prior to listing I went and got after the fact permits done on the work the prior owner did. I got full price for the house I sold, and tens of thousands off the house I bought.
Aggie67 is offline   Reply With Quote
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 03:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
