Permits Necessary? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 3 Post By Daniel Holzman
  • 1 Post By Msradell
  • 3 Post By IdahoBob
Old 12-23-2016, 01:23 PM   #1
Rewards Points: 4
Permits Necessary?
Hi All,
I have a rookie question in regards to building permits. I reside in a live/work loft in downtown Los Angeles and I am wanting to build somewhat of a cubicle. Management said I can build whatever I'd like just as long as it within the building code guidelines. As to try and avoid building permits I was wondering if it was possible to build an 11' x 16' cubicle, 8' high with no ceiling. My loft is 12' high so I would be building the cubicle's ceiling open to the entire loft room. This cubicle would act more as a room divider with a door.
I would be building the cubicle next to an existing wall which already has an outlet. Therefore, no electrical work needed.
Thank you for your thoughts.
Bob213 is offline   Reply With Quote
Old 12-23-2016, 02:59 PM   #2
Civil Engineer
Rewards Points: 4,858
Re: Permits Necessary?
Your building inspector will be happy to discuss the need for a building permit, and the process to apply for one if needed. No one on an internet chat forum such as this can offer you reliable information on the need for a building permit.
Dave Sal, Bud9051 and Mrbuilder like this.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Bob213 (12-24-2016)
Old 12-23-2016, 09:39 PM   #3
Msradell's Avatar
Rewards Points: 276
Since what you want to build it's going to be freestanding and contain no electrical, plumbing or any other utility it was mine I wouldn't worry about a building permit. Even though technically one may be required and the only way to find out would be to ask your local AHJ as suggested by Daniel.
123pugsy likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Bob213 (12-24-2016)
Old 12-23-2016, 10:29 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,986
As a general statement I would not thing your proposal would warrant a permit, but as others have said, your building department will be the final decider. Many municipalities, particularly large urban ones, have their own rules.
You mention "management" "live/work", which suggests a rental or some other type of multiple dwelling or commercial structure, which may change everything. I'm actually a little surprised they seem to be taking such a hands-off approach and taking a verbal statement on your intended construction (how will they know you don't end up building something with electrical and plumbing?)
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Bob213 (12-24-2016)
Old 12-24-2016, 06:42 PM   #5
Rewards Points: 18
Exclamation
The International Building Code requires permits for all partition construction over 5"-9" in height. More importantly the City of LA has strict rules for Live/Work buildings. As a former California Building Inspector (not LA) I can tell you that If your building was not legally permitted as "Joint Living and Working Quarters", there may be far more serious issues. The recent disaster in Oakland that claimed 36 lives was an example of what can go wrong in an unpermitted and non code-compliant live/work situation. Make sure you are living in a safe place.
Dave Sal, lenaitch and Mrbuilder like this.
IdahoBob is offline   Reply With Quote
The Following User Says Thank You to IdahoBob For This Useful Post:
Oso954 (12-25-2016)
Old 12-25-2016, 12:09 AM   #6
Rewards Points: 18
In my previous post the maximum partition height without a permit should have read 5'-9" (69").
Bob213 (12-26-2016)
Old 12-26-2016, 04:55 PM   #7
Rewards Points: 4
Thank you all for your advice and input. It is very much appreciated. IdahoBob, I will certainly look deeper into it. 69" is not a bad height. Thanks again.
Old 12-28-2016, 06:02 PM   #8
Rewards Points: 1,284
I would think as long as it isnt a structural component, a permit wouldnt be needed. My own opinion, but you did say LA - may want to at least make a random call to the city
KPDMinc is offline   Reply With Quote
Permits / Notice of Corrrection/ Hiring GC to help tinylittlething Building & Construction 34 08-21-2014 02:46 PM
Plumber didn't pull permits and work is not to code...what now? TwistedCubic General DIY Discussions 19 05-25-2013 10:24 PM
Open permits? WillK Building & Construction 1 09-10-2012 02:34 PM
Help ... permits joyjoy Remodeling 2 11-26-2010 06:30 AM
