Permit Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 02:13 PM   #1
Rewards Points: 640
permit problem
So I bought a house last year, it inspected perfectly, everything was great... after I bought it I found out the previous owners are the ones that finished the basement... that's where I started to get scared... I have been looking around, insulating hot water pipes, etc... then I noticed something... the new plumbing for the bathroom downstairs was done in a wierd way... almost all with flexable copper piping... odd... but didn't think too much about it then I ran into something when it got cold out... couldnt figure out why the basement was so cold.. the put supplemental electric heat in, ontop of the nat gas heat it had... but it was still cool... pushed up the drop cieling and felt behind the drywall and there is NOTHING behind it... no insulation at all... just 2x1 furring strips and drywall... well when talking to the permit person about the part I want to finish off (1/3rd of it is unfinished) I mentioned I wanted to get the whole basement done... he said I'd need to send in drawings for the whole basement... i said but the other 2/3rds of it was already done he gave me an uh huh kinda tone... then I said let me guess there is no permitted work for the basement... so turns out the contractor that did the basement NEVER GOT A PERMIT! ugh... now I'm in an interesting situation... I might have to rip it all out anyways because of the lack of R-10 insulation (what our area recommends)... any suggestions on what to do?
BlueBSH is offline   Reply With Quote
Old 12-28-2009, 11:19 PM   #2
Registered User
Rewards Points: 4,920
Did you check the City/County records for the work done? Moving ahead, get a permit which will probably require bringing the old work up to minimum code/safety standards. Which is a good thing, and it will be on the house's record, which is why we encourage getting permits.
Be safe, Gary
Tags
permits
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Permit Issue Foo by Tore General DIY Discussions 16 04-18-2008 10:42 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
