Old 02-23-2007, 11:10 PM   #1
Permit For Cement Work
What Must I Do To Apply For A Permit To Perform Sidework Repair In Queens
LOULUVSLORR is offline   Reply With Quote
Old 02-24-2007, 08:39 AM   #2
Hopefully someone from that area will answer you. Codes vary so much that ONLY your local code applies. Sidewalks are usually city property (even though you are responsible for upkeep) and must be done correctly. In Ohio, driveway approaches and side walks had to be 6 bag mix and (for sidewalks) 4" thick minimum. Good luck and call your local code office.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 11:34 AM
is this bad tiling work? garrick Flooring 17 09-27-2006 01:30 AM
