Is Permissible Per Manufacturer To Cut The Center Out Of A Tgi ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 07:39 PM   #1
Is permissible per manufacturer to cut the center out of a tgi ?
Is permissible per manufacturer to cut the center out of a tgi for enough room to install flex duct when the floor vent is against an outside wall. There seems to be no other alternative.
bcbearhnt is offline   Reply With Quote
Old 04-09-2010, 08:25 PM   #2
Pro
Nostco's Avatar
Depends on the size of the joist and how much you're cutting. General rule, not 2" from the top or bottom and 33% of the total width of the joist.
Other words, you have a 12" joist, Max 4" cut and not the top 2" or bottom 2".
BTW, It's TJI not TGI.
Nostco is offline   Reply With Quote
Old 04-09-2010, 10:09 PM   #3
Registered User
Rewards Points: 4,894
http://www.ilevel.com/literature/TJ-4000.pdf
Be safe, Gary
Old 04-09-2010, 10:13 PM   #4
remodeling pro
Those numbers sound more like dimension lumber that TJI's. Unless guidelines have changed, you could cut the web out to within 1/4" of the flanges; absolutely do not overcut and scar the flanges. I'm not quite clear on your description of the situation, but if the cuts are close to the ends of the joist where they bear on a wall, you are in the area that is most restricted. Engineered joists are opposite of dimension lumber in this
respect..you have more freedom when you get away from the bearing points, unlike dimension lumber, where you try to keep penetrations close to te bearing points whenever possible.
ALWAYS CHECK THE FACTORY INSTALLATION GUIDE SPECIFIC TO THE MANUFACTURER OF YOUR PRODUCT, YOU DON'T WANT TO VOID THE WARRANTY OVER A SIMPLE ERROR.
troubleseeker is offline   Reply With Quote
Old 04-10-2010, 02:17 AM   #5
Rewards Points: 1,092
plus...
If not implied in what Nosco posted, there are also limits on how much of the web you can destroy along the length. Certain sized holes need to be X inches apart, etc. The lumber company should have the specs on their particular BCI, TJI, or whatever brand you have.
Old 04-10-2010, 08:43 AM   #6
Framing Contractor
You HAVE to follow the I-joist manufacture installation guide that GBR posted a link too. That's the only way to do it.
Joe Carola
Joe Carola is offline   Reply With Quote
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 07:50 AM
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 07:56 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
