Permanant Wood Foundations - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2008, 01:02 PM   #1
I'm looking for any info on PWF. There's a lot of good things being written about it by the companies who provide the materials and installation, but I am looking for any good or bad experiences with the system.
PaulKatrinaJake is offline   Reply With Quote
Old 07-30-2008, 01:41 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
They have been around since the 1960's and have not taken hold (possibly decreased) since 1975. The only ones I have seen had problems because of my engineering background and being called in.
concretemasonry is online now   Reply With Quote
Old 07-30-2008, 04:06 PM   #3
Registered User
Termite's Avatar
They are used in some areas. Particularly areas with good drainage.
There is a big huge section in the IRC code that covers how they have to be built.
Personally, I wouldn't have one. No way, no how.
Old 06-20-2009, 09:47 AM   #4
I too am looking into this for a new addittion to my bungalow. From what I have read so far its all about proper engineering. Check out this link . Interesting read.
I realize this post is a year later. If you finally went with a PWF maybe you can share this experience ?
http://www.bobvila.com/BBS/Permanent...s-1-T4016.html
offroader6387 is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
