Perimeter Footer Under Mobile Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 07:44 PM   #1
Perimeter footer under mobile home
Can't get the specs on a footer under a 28x60 MH. I'm putting 8" block up to ledger under the outer walls. Calls to the local inspector aren't returned and I want to get going. It doesn't support but it's own weight so I'm figuring 8x16 with 2 runs of #4 bar. Too much or too little?
ogyver is offline   Reply With Quote
Old 03-10-2011, 08:12 PM   #2
Rewards Points: 150
Don't know what part of the country you're in, but just be sure you cut a piece of 2x8 lumber 16 or 24 inches and see that it fits between footer and trailer frame, when you do the footer. Yes two lengths of rebar is fine in footer. Lay your block up on the corners first. Above all make sure your trailer is dead level, before you start
bernieb is offline   Reply With Quote
Old 03-10-2011, 08:19 PM   #3
Rewards Points: 150
You may consider piering down with a post hole digger every 12 feet when you put the footer in.
Old 03-13-2011, 07:38 PM   #4
Thanks for the height tip. I'm leveling it, re-plumbing it, moving the water heater for a new packaged heat pump intake, removing the propane furnace and AC. I'm going to put tan split face concrete block around the perimeter.
running electric under mobile home brianbrianj Electrical 8 10-26-2014 03:16 PM
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 03:13 PM
Dyrwall for Mobile Home Suncrest79 Building & Construction 3 03-04-2009 08:05 AM
deck for a mobile home rln17 Building & Construction 2 09-09-2008 05:51 PM
Mobile home electric. RobertS Electrical 7 02-27-2008 01:25 PM
