Perimeter Beam Cutting - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-30-2008, 10:23 PM   #16
BUILDER / REMODELING CONT
buletbob's Avatar
Originally Posted by MdangermouseM View Post
i still have no viable solution to this, anyone else have any ideas? maybe a new thread? hasn't ANYone ever had a 2x12 inside and out to hold the rafters and found a good way to hide them? i simply refuse to believe the GOV. let them do this if no-one has ever done it before.
and how do i fix this screw up they did? the sagging beam??
DM
To be honest with you the only time i have seen post and beam was for barns and storage shed's. besides a few house's around here from the 1700's
BOB
Old 08-30-2008, 11:36 PM   #17
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
How about a few more pics please. I can't seem to get the whole thing envisioned in my head. There is always a fix. It might be a one off way of doing it.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 08-31-2008, 09:00 AM   #18
the Musigician
DangerMouse's Avatar
ok, more pics on the way. maybe even today if i get time to rake them and post. =o)
DM
Old 08-31-2008, 10:55 AM   #19
the Musigician
Smile
welcome to my nightmare....
ask and ye shall recieve....( I WISH!)
pics done, resized and optimized.....here we go.... 6 more to follow in a sec.
DM
perimeter beam cutting-100_0307.jpg   perimeter beam cutting-100_0308.jpg   perimeter beam cutting-100_0309.jpg   perimeter beam cutting-100_0310.jpg   perimeter beam cutting-100_0311.jpg
Old 08-31-2008, 11:15 AM   #20
the Musigician
the rest of the pics
and the rest....
DM
perimeter beam cutting-100_0313.jpg   perimeter beam cutting-100_0314.jpg   perimeter beam cutting-100_0315.jpg   perimeter beam cutting-100_0316.jpg   perimeter beam cutting-100_0319.jpg
Old 08-31-2008, 03:39 PM   #21
Registered User
Termite's Avatar
The place seems to be coming along pretty well.
OK, something I'm not 100% clear on...
Did the beams sag, or did the entire structure sag due to footing movement? Basically, did the posts move?
I still say that the connection between the posts and the 2x12's is weak.
Short of continuous soffits or furring the exterior walls out 1-1/2", there is no way to hide the 2x12's projection from the face of the wall. Have you considered furring? You'd have to re-rock though. Forethought, my friend...Forethought!
Old 08-31-2008, 04:01 PM   #22
the Musigician
yes, i thought of that, but 10" plus thick walls? remember, those 2x12s are inside AND outside.
Old 08-31-2008, 04:06 PM   #23
the Musigician
because of the roofline being clean, i think the post sunk in the year it sat waiting. (or pad cracked from not enough 'crete) then the second guy shimmed perhaps to flush it. i was out of town when he did that section, and now it's unviewable. the 2x12 did not shift on the post so far as i can see.
DM
Old 08-31-2008, 04:16 PM   #24
the Musigician
also, because of how little weight that 6' 2X12 is supporting, and the fact there's another better one outside, i see no harm to it's integrity if i slice off that 1" to 0" part to level the sheetrock top. then furring the ceiling from that end 0 to 1" at the other end. that would also help hide the steel supports. but i need to know if the inspector will poopoo it and make me pull it and replace?
DM
Old 08-31-2008, 04:21 PM   #25
the Musigician
oh yeah, and pls note the walnut door trim i created from trees in my woods, and the jarrah light switch cover i did from scraps from the porch. =o)
always recycle when possible!
DM
Old 08-31-2008, 04:27 PM   #26
Registered User
Termite's Avatar
As unreasonable as it may seem, I'd make you replace it or get an engineer to sign it off as soon as you rip the edge of that 2x12. Ripping graded lumber absolutely negates the grade stamp and makes it unusable in a structural span application. You should talk it over with the inspector prior to doing it.
Old 08-31-2008, 04:31 PM   #27
the Musigician
also note the pic of the round corner turntable cupboards... (5 bucks each at habitat for humanity, where i seem to be buying more and more supplies as prices keep going up and up) i really only have need for one, but what the hey, i'll find somewhere else to use the other, the wife loves those things. =o)
DM
Old 08-31-2008, 04:36 PM   #28
the Musigician
i'll buy that kc, how about if i pulled the inside one off completely and just notched it on top to fit around the bottoms of the rafter bottoms? any problems with that? (other than the removal of the steel support bracket nails i just remembered... but they can be reattached) and my building inspector is in alaska right now, i guess when they expanded his territory, they REALLY expanded it!
DM
Old 08-31-2008, 04:39 PM   #29
Registered User
Termite's Avatar
You're getting off topic with doors and cabinets and lightswitches Dangermouse!
You should create a new thread in the project showcase section to show off and chronicle your project! That way you can post pics of your progress for everyone to see without it getting lost.
Old 08-31-2008, 04:41 PM   #30
Registered User
Termite's Avatar
Do you know what code they're enforcing up there?
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
