Pergola Wood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 11:49 PM   #1
Pergola wood
Hi,
I'm planning a 12' square pergola using knotty ceder. The posts will be set 10' apart. I am planning to use 2x6. Thing they will sag over that span?
Thanks!
JamesMop is offline   Reply With Quote
Old 08-05-2012, 04:18 AM   #2
Rewards Points: 502
Pergola wood
Originally Posted by JamesMop View Post
Hi,
Yes, they will sag; technically any beam will sag, even under its own weight and on a very short span.
The qustion should be: how much sag are you prepared to accept, ie will it be noticeable?
However, I was just hair-splitting. Back on Planet Earth,I don't think you will have any practical problem with sagging (more correctly known in the trade as 'deflection').
(Where I am, our code allows 2x6 for floor joists at 16" centres over just short of a 10ft span, with low (ie un-noticeable) deflection, so your pergola beams will be just fine).
There might be a slight tendency to twist, so are you putting some blocking pieces between them?
tony.g is offline   Reply With Quote
Old 08-05-2012, 10:44 PM   #3
Pergola wood
Thanks for the reply.
I was planning to run 24" centers both parallel and perpendicular to the house, sort of a grid design. I planned on using a double 2x6 around the perimeter but I've been reading that I'd be better off using a wider board instead of doubling. I'm not sure which would be sturdier/ look better.
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
