Pergola Sanity Check - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 08:08 AM   #1
rem
Would anyone review this design and give me a gut check. I attached a top and side view of a pergola I want to build. I'm using a 6x6x1'6" insted of a ledger boad to hold 2 2x12x16, sandwiched style. The span between 2 of these is about 14'. Accross the span I'll use either 2x4x16 or 2x6x16. The outside colums are 6x6 posts with Fiberglass wraps and a stone 32" base. I'm putting this on 16'x16'x4" pad and the back of the house is stuco, 2x6 walls. I'll predrill everything and may subsitute a 4x12x16 for the 2x12 sandwich. The 2x12s are cut to be curved. See anything wrong with this idea?
Thanks Rob
rem is offline   Reply With Quote
Old 03-22-2009, 08:18 AM   #2
Rewards Points: 5,336
The 2x4's or 2x6's are too small to span the space. They will sink in the middle over time.
Ron
Old 03-22-2009, 11:35 AM   #3
rem
Pergola
Should I drop the 2x12s to 2x10s and add one more row so they will span?
Old 03-22-2009, 07:46 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Not only will they sag, they'll bow and twist and warp all over the place. you need something to tie them together mid span. Maybe two places.
Old 03-22-2009, 09:31 PM   #5
If you add another row of support it will cut the span to 7', well within the no sag issue of a 2x6. As Maintenance 6 said, you would also need blocking of some sort to prevent twist.
Ron
Old 03-23-2009, 04:45 PM   #6
rem
Another design
I've change the design to incude another row and a cross member between the posts. Does this seem like i'm in the right direction?
Old 03-24-2009, 06:58 AM   #7
You realize that your shadow lines are going to vary across the curves. From below the 2x4s on the inside of the curve are going to appear closer together, while the ones on the outside of the curve will look further apart.
Old 03-24-2009, 07:29 PM   #8
rem
Yeah, good point, I think it gives it some character. I'm one for not always going with the 90 degree cuts or straight lines.
I've been looking at cedar beams insted of the 2x10s. Know of anyone having good luck with say 4x10x16? I'm not sure what all sizes they come in.
Old 03-24-2009, 08:23 PM   #9
I was thinking all cedar and maybe 2X2 instead of 2X4 or 2X6's. Cedars lighter and will handle the weather better.
II Weeks is offline   Reply With Quote
Old 03-24-2009, 08:42 PM   #10
You're sort of back where you started. The 2x2's will sag spanning that distance.
Ron
If you put the 2x2's on top of the current setup, it would work.
Sanity Check apetrag Plumbing 9 02-20-2009 11:45 PM
Sanity check - water collection for irrigation - from creek bed So cal Man Landscaping & Lawn Care 2 08-14-2008 06:16 PM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 08:30 PM
concrete bid sanity check Brandon Gollaher Building & Construction 10 10-09-2006 08:51 PM
