Pergola Posts Splitting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 01:52 PM   #1
Pergola posts splitting
New to the forum and have a question. Recently had a pergola built and almost every one of the posts (8x8) are showing significant splits, some being worse than the others. I was told by the company the built it during construction (i first noticed some before it was completed) that all of the posts are center cut and not to worry. I'm more concerned now because a couple have gotten significantly worse since completion, and it's only been a couple of weeks. Should I be concerned? See pictures.
Hoover8 is offline   Reply With Quote
Old 10-04-2010, 07:50 PM   #2
Rewards Points: 5,336
You don't mention which wood was used. If it was pressure treated, checking(splitting) of the wood is to be expected. Generally more cosmetic then structural.
Ron
Old 10-04-2010, 10:24 PM   #3
jlhaslip's Avatar
Rewards Points: 396
Looks okay to me.
Posts should be free of heart centre material to avoid checking, and the ends could have been sealed, but those pictures wouldn't bother me. Wood checks. It can't be entirely stopped. Those checks aren't an issue.
Add a coat of stain next Spring.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Pergola Posts a Little Wobbly Mr.S Teacher Building & Construction 11 03-24-2012 07:55 PM
Pergola construction - beam span without sagging fahartle Building & Construction 9 07-25-2010 08:54 PM
One of the posts on my deck is splitting, fix ? Scott Stevens Building & Construction 1 05-19-2010 07:27 PM
help - pressure treated 4x4 deck posts splitting frank090870 Carpentry 17 05-03-2009 07:19 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
