Pergola Framing ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 09:49 AM   #1
Rewards Points: 91
pergola framing ?
i am planning on adding brackets on the end wall of my addition that stick out 3' and creating a pergola roof to bock some sun. I didn't want to run tall header beams but maybe a double or triple 2x6 or 2x8....
how far apart can I span these brackets? thanks
gwilkrrs is offline   Reply With Quote
Old 07-11-2013, 11:20 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
It is a free country, you can span them however much you want on your own property.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 07-12-2013, 05:54 AM   #3
roofingquotes's Avatar
I think there's no standard size for a pergola frame. So far I've seen pergola frame about 12x16-20. There shouldn't be a problem with the size you have in mind.
roofingquotes is offline   Reply With Quote
Old 07-15-2013, 11:34 AM   #4
Rewards Points: 91
is there a recommended span between supports? I am looking at around 12' to 18' between supporting brackets..... and don't want it to sag in the middle in time.....
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Pergola framing question Latechslack Carpentry 3 04-03-2009 06:39 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
