Pergola Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 09:34 PM   #1
pergola construction
I plan to build a pergola, with support beams running perpendicular to the house, and the rafters parallel. A ledger is not possible, how do I attach the beams to the brick wall?
jazzbrek is offline   Reply With Quote
Old 05-29-2011, 09:47 PM   #2
Rewards Points: 1,016
Brick veneer with wood framing?
Why is a ledger board not possible?
The Following User Says Thank You to vsheetz For This Useful Post:
jazzbrek (05-30-2011)
Old 05-29-2011, 10:43 PM   #3
Rewards Points: 5,336
Don't attach it to the wall, make it free standing.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 05-30-2011, 11:11 AM   #4
Thanks for your response. A ledger board would cover 2 windows and a sliding patio door, so my plan was to fasten the beams directly to the house outside these features. Jazzbrek
Old 05-30-2011, 11:15 AM   #5
Ron
Thanks for your response Ron. You may be right, others have suggested the same thing. Jazzbrek
Old 05-30-2011, 11:28 AM   #6
Sounds like you may be trying to deal with a situation somewhat like I had to - coming off a single story house resulting in the pergula being rather low.
One solution is to build it free standing but that did not appeal to me. So instead I removed the eave facer/facia boards allowing me to install a ledger board and subsequently the rafters 6-8" higher. I then placed the beams on top rather than on bottom to remove them from protruding down into the view, using what I call 'hanging posts'. I finished the connection to the house by boxing in the eave area and installing down lighting to wash the wall with light - looks great at night.
Here are some pictures. http://www.webjeepers.com/homestead.html
Hope this may help.
Old 05-30-2011, 04:43 PM   #7
Hope this may help.
Thanks again for your comments and good pic's. Very nice looking...interestin construction...will be helpful in my planning. Larry @ jazzbrek
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 07:05 PM
Pergola construction - beam span without sagging fahartle Building & Construction 9 07-25-2010 08:54 PM
Pergola on Elevated Deck stubits Building & Construction 0 06-19-2010 09:48 AM
Attached Pergola stubits Building & Construction 5 08-01-2009 02:07 PM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 09:30 PM
