Pergola To Brick Veneer Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 11:28 PM   #1
pergola to brick veneer wall
Is it possible to join a pergola to an existing brick veneer wall
Lorraine Rivet is offline   Reply With Quote
Old 02-11-2011, 07:25 AM   #2
Rewards Points: 5,336
It's possible, but I would not recommend it. The brick has no structural integrity for it.
Better to set 2 posts next to the structure.
Ron
Old 02-11-2011, 10:11 AM   #3
Aren't pergolas supposed to be freestanding?
mrgins is offline   Reply With Quote
Old 02-11-2011, 01:08 PM   #4
What are you saying? That there are no loads on them? That they have 4 posts?
Is Nathan starting to charge by the word?
Ron
Old 02-11-2011, 01:53 PM   #5
Ron
I didn't quite follow that, Ron! Must be the drugs from my knee op
My pergola (btw, where is the emphasis applied on that word?) is supported by four posts with brackets at the top to support lateral movement.
Old 02-11-2011, 02:18 PM   #6
Got it.
The poster wants it attached to the house, which in their case is a brick veneer. It can be attached to the structure, just not to the brick. I don't know if they're willing to open the interior wall to structure it so the load is properly supported.
Or... it could be the meds.
Ron
Old 02-11-2011, 02:31 PM   #7
Maybe she could Rivet it! Yeah, that one was def. the meds
So, OP, why do you want to attach it to the house?
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Garage brick wall repair TANME General DIY Discussions 2 02-04-2010 06:19 AM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
