Old 06-18-2012, 11:50 AM   #1
Pergola Attached to Second Story Deck
Hello,
I am in the process of redecking a sound, but left untreated deck. I am replacing the deck boards and railings only, and sanding/staining the structural members.
I had a thought that I may be able to add a small pergola to the deck.
Do you have any thoughts on this design?
Deck:
14 x 16 long, 2 x 8 Boards
2 x 10 16 OC, Half cantilevered on the sides, the with the middle boards joist hangered on due to a doorwall protrusion
The two end joists have sistered 2 x 12 cantileveverd boards to make a groove for decking
The end of the Deck has 4 x 6 posts (3x) going into concrete piers. All of the joists rest on 2 2x12 boards that are lagbolted into the posts, one on each side of the post.
Pergola:
There are 4 x 4 railing posts. One On each corner, and a middle post on each side. Each is attached inside the farthest joist using blocking (The full length of the 2 x 10)
I was going to take the middle posts on the side, plus the far corner posts, and extend these upwards by 5 more feet
I would then lag bolt in 2 x 6 boards at the top going lengthwise, then add 2 x 6 pergola beams across the deck with. I was going to use 2 x 6 to cut down on weight and wind drag
Sorry for the bad drawing. I'll clarify if there is something that is illegible!
kaalapurushha is offline   Reply With Quote
Old 06-19-2012, 08:58 AM   #2
Bueller?
Old 06-19-2012, 11:01 AM   #3
Maryland
What drawing?
Pittsville is offline   Reply With Quote
Old 06-19-2012, 11:10 AM   #4
Renovations contractor
Bonzai's Avatar
Really need to see a drawing to understand properly what you are proposing. A pergola would normally involve a beam supported on top of the posts and then the joists extend out and notched over this ... As opposed to lag bolting in to the side of the posts. I'm not saying it can't be done as it's non structural but if you google "pergola design" you'll see how one traditionally is built. Again a picture may confirm or otherwise what I am trying to imagine you're design is.
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 06-19-2012, 11:32 AM   #5
I think I have come to that conclusion also after doing more research.
My main concern was whether I could attatch the deck to the pergola without having the pergola posts drop down to new concrete piers.
I made another sketch showing what the pergola would look like. The posts would be notched into the 2 x 12 "side joists". (Note, the other joists are 2 x 10, but the two ends are 2 x 12)
If you look at the original drawing, the pergola would be on the two sets of leftmost 4 x 4s.
Attaching a pergola to a home and deck. nickf829 Building & Construction 1 03-15-2011 02:20 PM
Installing pergola on raised deck. Daverimmer Building & Construction 29 03-15-2011 02:15 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Pergola over Deck Question figgyb44 Building & Construction 2 06-10-2008 08:50 PM
