-   -   perforated wall drain pipe (http://www.diychatroom.com/f19/perforated-wall-drain-pipe-85490/)
amakarevic 11-01-2010 01:38 PM
i am building a small, 1 ft tall by about 20 ft long retention wall. i need it because my backyard on one side is elevated relative to the neighbor and not on the other side and i have a shed whose footing i would like to keep in place.
over time, i have witnessed how the soil expands with rain and even experimented with small cinder block walls (unmortared) which would crumble under wet soil expanding like a card tower.
so i went full force and set an array of five 3ft deep piers, 3 of which i am also using for my deck and want to connect them with a small wall (more like 4 little walls). i want the wall to be about 1 foot deep, the elevation of my shed platform is about 8 inches higher than the neighbor's yard + some footing. at about the level of his yard, or maybe a couple inches above, i wanna set 2 perforated drain pipes in each wall segment (4 of them) to drain the water from my elevated yard (basically surrounding of the shed). questions:
1. what size pipe would be adequate, i was thinking 1.5" ?
2. how deep should the pipe go into the soil my side ? is a couple feet OK or should it be more or less ?
3. should i buy a pre-perforated pipe (HD didn't have it) or should i use regular PVC pipe and drill my own holes?
thanks
stadry 11-01-2010 02:54 PM
only 1 ft tall by about 2 ft long ? ? ? ? why bother w/anything when you can just grade the center of the 2' higher than either end ? ? ?
4" coils x 50' are avail in apron store garden sections along w/10' pieces of the same - either slot OR w/holes - get sewer & drainage pipe inside ( plumbing ),,, we also line the system w/filter cloth & backfill w/clean #57 stone.
amakarevic 11-01-2010 03:19 PM
20 ft, typo, sorry :wallbash:
stadry 11-01-2010 06:56 PM
dammit, you're an experienced poster, too,,, pay attn from now on :laughing: ok, so get TWO 10' lengths :thumbsup:
