Im looking to build a peninsula to extend out our counter tops, and Im having some issues with what to do with the cabinets. Usually are they not screwed to the floor / wall / ect?
I cant do that cause the floor is "floating" and if you screw anything into it, and then into the sub-flooring, you kinda loose the "floating" thing.
Will the weight of the new counter tops ( solid surf ) be enough to hold all this together if I was to attempt to screw it to another and then to the existing cabinets where they do connect?
Here is what we have currently minus the island as that was pulled out when I re-did the floors:
And here is what I want to attach on the side of the dishwasher that you see above with the cabinets facing the inside of the kitchen:
Thanx in advance.
