Peeling Exterior Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2009, 01:02 PM   #1
Exclamation
Peeling exterior porch
I need some help. My exterior entry porch paint peels excessively and has to be repainted every year...or more. There is also some rot. There is no vapor barrier underneath. I think that's the problem. I cannot access the area under the porch however, without destroying it. Can I tile? Is there any spray vapor barrier? Thank you.
christinecfrost is offline   Reply With Quote
Old 08-27-2009, 09:30 PM   #2
Registered User
Rewards Points: 4,924
I would remove enough decking to get into the space and install a v.b. on the dirt. Check the floor assembly carefully for rot and damage. It may be more extensive than you think, or not. If you are seeing rot, there is more. I prime my deck boards on the bottoms before installation. Open a vent at each end for cross-flow, to help dry and stay dry. If you tile over existing, the rot will continue as it is caused by a fungus. The boards are trying to dry out through the tops, but the paint stops it, hence the peeling and flaking paint. Do not use oil-based as it will rot quicker. Can you vent in a rim-end joist? A picture would help.
Be safe, G
Old 08-29-2009, 01:22 PM   #3
Follow up
Thank you, G. Unfortunately it's a rather small deck and I'd have to destroy it to pull up any boards to get underneath. Former home owner cut a lot of corners I'm finding. Is there any such thing as spray on vapor barrier? Would stripping it and just staining it work? THanks again. -C
Old 08-29-2009, 04:51 PM   #4
Registered User
You could spray insulate the dirt.... though I never heard it done before. How would you spray it without pulling any boards? What is the condition of the framing? Is there active fungus and mildew? How far does the rot go, how deep? Be safe, G
Tags
porch , vapor barrier
Peeling house stain janecjh Painting 4 05-15-2009 11:01 AM
paint peeling everywhere jheavner Painting 5 09-03-2008 10:07 AM
pillars are peeling mamabear34229 Painting 5 07-28-2008 11:36 AM
peeling paint stallinc Painting 3 01-17-2008 09:53 AM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
