Peeling Drywall-tape Corners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2009, 12:31 PM   #1
Toe
Question
Peeling drywall-tape corners
I have a couple corners where the tape seems to have lifted slightly away from the wall. You can see a crack going up much of the corner, which apparently is the tape cracking the paint and pulling away from the wall.
Can I just sand and mud over this, or do I need to rip the tape off the whole corner and re-do it?
Thanks!
Toe is offline   Reply With Quote
Old 10-17-2009, 12:47 PM   #2
Toe
Whoops. I just realized it's not tape, it's metal corners.
So what can I do? Screw/nail it down then sand/mud?
Old 10-17-2009, 04:26 PM   #3
Drywall contractor
Rewards Points: 1,070
Nail it back down and mud it......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
corner , drywall , drywall tape , tape
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall tape sticking out vancouver Drywall & Plaster 5 09-08-2009 10:04 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 09:27 PM
How to use non-adhesive drywall tape? tripower Building & Construction 1 05-28-2007 09:29 AM
