Peel-Off Vs Non-peel-off Paste Epoxy - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 09:25 PM   #1
Rewards Points: 244
Question
Peel-Off vs non-peel-off Paste Epoxy
So, I have cracks in my basement to seal. I decided to use low injection epoxy seal. In determining the diy kit, I notice there are two kinds: peel-off and non-peel-off.
I know the difference, but I am wondering if one better than the other. Has anyone use them? Are the plugs snap right off, or do I need to cut them?
I am planning to install extruded polystyrene panels on the basement wall. I am concern that the non-peel will cause the panel not to stick properly to the concrete wall as I tried to create no air gap.
Here is the link:
http://www.appliedtechnologies.com/h...poxy_kits.html
325_man is offline   Reply With Quote
Old 12-22-2012, 05:56 AM   #2
Rewards Points: 4,656
know it sez diy but you determine mtl selection,,, we 'butter' crks w/hydraulic then drill for injection ports,,, sometimes we remove 'butter' but only for aesthetics.
you meant low pressure, right ? anyways, sometimes ports come right out OR they're a large pita,,, any success depends on installer skill & mtl selected,,, i never used surface ports - they're for diy'er wannabee's impo,,, when i learned as the 'helper' it was 5yrs before any installing company let me put my hands on their guarantee.
suggest either do it right OR call a pro - here in atl the rate's about $ 750 for a wall crk including mtl,,, the nice part about it is you don't have to wonder who to call back since you didn't diy
ps - have used appliedtechnologies & had no issues w/their mtl
Old 12-22-2012, 07:28 AM   #3
Rewards Points: 244
I had several cracks repaired already by pro who told me nothing more than "I'm done" and give me warranty that they won't leak. I am not sure how to deal with them as i want to insulate the basement properly. Can I just chisel it off?? Will it void the warranty?
Old 12-23-2012, 04:13 AM   #4
most use f/g to insulate & the 'buttering' isn't normally more than 1/16-1/8" thick so that shouldn't negate or measurably diminish any insulation properties,,, even if you were to use foam insulation, i don't see it as a problem leaving it in place..
short answers: 1st - yes since its your house 2nd - don't know, ask them - its their warranty & we've no idea of the work's original intent - weld a broken conc wall OR stop a leaking crack
Elasticity during curing of PV7 epoxy paste DiegoJames Plumbing 0 08-05-2012 04:20 PM
Epoxy Questions bsmith95610 Flooring 11 04-02-2011 03:41 PM
filling crack in a wood floor debd Flooring 2 12-30-2008 06:22 AM
Bathtub Chipping In Bottom llg871 Remodeling 3 12-17-2008 11:32 PM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 03:55 PM
