Pebbles Showing Through Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 09:52 PM   #1
Rewards Points: 192
Pebbles showing through concrete
Hi,
We're building a house and the just got done pouring the concrete and removing the forms for the walls. I went there today while they were spraying the waterproof membrane, and snapped some pictures.
I had a question about how the concrete looks. On the inside, it looks fine. On the outside, there are two or three areas where the rocks in the concrete have shown through. Here are the areas of concern...
This one is where the front porch will be. There's no 'basement' area underneath the front porch. In this picture, it's about a four foot wall that has a footer underneath it. My concern is the rocks and cracks. Will this cause problems for me in the future? Is there a fix if there is a problem?
The second question I have is this one.
This is a little different because this is where the 'lookout windows' will be placed. So in this area, it will be in the basement. It's basically the corner of the basement. On the upper-left hand side of the picture is where the garage is. This is not excavated, but there is an 8' wall over here because of the lookout.
There is one more spot that's on the corner, but it's basically the same thing...where the rocks on the concrete are poking through.
I'm not an expert and that's why I'm coming here for a non-biased answer. Is this normal? Should I be concerned or worried? Will it crumble in the future?
Thanks in advanced...
Last edited by wiz561; 07-20-2010 at 10:20 PM. Reason: changed throw to threw in the subject.
wiz561 is offline   Reply With Quote
Old 07-20-2010, 10:48 PM   #2
Old School
Willie T's Avatar
I suppose there could be a measurable strength loss somewhere there. But I doubt it will effect your building one bit. Just have the contractor slurry it up with fill. This is a bit extreme, but similiar pours are not uncommon in most construction today.
Willie T
Old 07-20-2010, 11:00 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
The contractor did not know how to place concrete and should do the repairs. - Lack of vibration causing what is called "honeycombing". Hopefully it is not on both sides, but the other side and adjacent will not be as they should be.
Probably not a structural problem, but should be corrected as soon as possible for a good repair or you can have water problems.
Dick
concretemasonry is offline   Reply With Quote
Old 07-21-2010, 06:26 AM   #4
Concrete & Masonry
Rewards Points: 548
Originally Posted by wiz561 View Post
I'm not an expert and that's why I'm coming here for a non-biased answer. Is this normal? Somewhat common, yes. Should I be concerned or worried? No. Will it crumble in the future? It will last longer than any other element of the house that sits's on it.
Thise walls actually look fairly good IMO, especially for the Advance 4 band sytem that they used.
jomama45 is offline   Reply With Quote
Old 07-21-2010, 07:45 AM   #5
Rewards Points: 192
Thank you all for the responses. I was thinking about this last night and a little this-morning, and it probably shouldn't be anything of concern. I figured that when you pour a sidewalk, the underbelly of it probably looks like this. Sidewalks last forever, so this should too.
I just figured that it was something that stuck out from the rest of the area. Everything else is smooth, so I figured that if one or two things are different, it might be something to question.
What is the 'Advance 4 band" system? I did a google search on it and I got everything from cellular bands to lap bands. When they put the forms up, I did catch the name "Duraform". I just assumed it was the name of the forms that allow a non-stick like surface. Is duraform a commercial name of the advance 4 band system?
Thanks!
Old 07-21-2010, 07:50 AM   #6
Rewards Points: 4,584
you're getting diverse opinions above & they're probably all correct altho i'd side w/dick more than will or jo.
whoever was on the vibrator didn't do so hot but the repair's easy enough to do,,, i'd also be concerned about the dampproofing that's been applied,,, as the foundation moves,there's a great probability of water intrusion,,, doubt the walls're poured over waterstop so NOW's the time to fix that item imn-s-hfo
stadry is online now   Reply With Quote
Old 07-21-2010, 09:10 AM   #7
Jack of all master of sum
Curious to know, was the concrete placed with a telebelt?, inexperienced telebelt operator and \ or inexperienced placer will yield the same results, but it's an easy fix and generally nothing to worry about structurally . See this all the time in production homes ( Lego sets), usually in the garage drops. looks to be a builder grade ( min Building Code) 15 mpa concrete. Kinda looks like a cold joint in the fruit cellar. Also it's not very often I see anybody vibrate a residential wall, generally the only residential walls that get vibrated around here are ICF walls, I have pumped hundreds of them.
BobCaygeon is offline   Reply With Quote
Old 07-21-2010, 10:53 AM   #8
Rewards Points: 192
I actually don't know how the concrete was poured, as I missed out watching it. It would have been cool to see it done.
Thanks for all the comments. It's great to get an experts opinion!
Old 07-21-2010, 03:35 PM   #9
Concrete & Masonry
Rewards Points: 548
Advance & Duraform are the same thing, and I actually think Advanced may have bought Duraform out years ago. Either way, they're a 1 1/8" plywood panel with 4 steel bands across them to hold the clips to the form permanently. The make 4, 5 & 6 band in the 8' height (yes, I know you have a 9' basement though ) with the 6 band being the most "stout" and flexible for the concrete placement.
The honeycomb in the stoop looks bad, but the fill will be balanced in the end, so the walls wil be doing very little and should have no problem.
The basement corner honeycomb is minimal IMO, and it would definately help asthetically to have them slurry over it. The slurry will do little to nothing for the integrity of the wall, which isn't compromised substantially anyways. It's not that uncommon to get a little honeycomb on the corners with this system.
As for the vibrating, it would be risky business plunging any kind of vibrator with a head bigger than an inch in those walls with the 4 band system. I definately wouldn't be standing near during vibration, much less on the wall. I've seen far too many blow-outs with the 4 bands in my younger days.
Old 07-22-2010, 06:04 PM   #10
Rewards Points: 192
low ae
Hi,
Another (related) question. The "mix description" was a "3000 psi low ae". What is 'low ae'?
Thanks!
Old 07-22-2010, 06:07 PM   #11
Rewards Points: 192
Sorry...I found that "AE" stands for Air-Entrained Concrete. Should have dug deeper before posting.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Darn! Trying to find Ahmed's concrete overlay using pebbles and epoxy on patio BillieJeanR General DIY Discussions 10 04-21-2010 08:43 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Freshly poured concrete rocks showing through top of it why? yo24 Building & Construction 3 01-28-2009 05:25 PM
