Pebbled Stucco / Concrete Foundation Veneering? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 05:03 PM   #1
Forgive me if this is common and known under some name I can't find it under...
Has anyone tried to finish a foundation exterior base with applying a base mortar coat and then troweling/throwing on gravel into the bed to achieve this sort of look - Pebbledashing. If so, any tips or suggestions would be much appreciated. I had been looking into re-stuccoing or applying ledgestone veneer to my foundation base but had this idea. Any thoughts/tips, and how this idea might compare in cost, ease of install, and weathering? Thanks much!
http://us.123rf.com/400wm/400/400/bo...-like-wall.jpg
http://www.businesscards2k.com/cards...7vnqwx_300.jpg
Should I worry this will happen? Yikes!
http://www.eurocote.co.uk/images/Pebble_dash_cracks.jpg
p.s. sorry for not attaching as pics - on my cell and doesn't allow.
99altrade is offline   Reply With Quote
Old 06-21-2011, 05:35 PM   #2
I just read this on Wikipedia. WTF, for real? I would think tastefully done with other types of materials on the exterior it would be attractive.
"Though it is an occasional home-design fad, its general unpopularity is estimated to reduce the value of a property by up to 5%.[1]"
Old 06-21-2011, 06:03 PM   #3
Rewards Points: 552
Pebbledash used to be quite popular here, but has gone out of fashion now. It can be difficult to patch if any bits fall off.
It's best to use a waterproofer in the scratch coat. The top, or butter coat needs lime in the mix. The secret is to throw on the pebbles with a harling trowel when the mix has gone off just enough to hold them. Don't stand too close so the pebbles get a good spread. Don't try and cover all in on go, but go over it quite a few times. Then push them home with a wooden float.
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
jomama45 (06-21-2011)
affixing PT 2x4 sole plates to concrete foundation amakarevic Building & Construction 6 12-21-2010 09:28 PM
concrete over cinder blocks for foundation?? Birdman79 Building & Construction 10 11-24-2010 02:32 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Tinted concrete sealer to change color of stucco exterior? TomServo Building & Construction 3 04-19-2010 08:10 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 02:01 PM
