Pea Gravel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2007, 01:29 PM   #1
pea gravel
I opted not to set my fence post in concrete because I'll be replacing it in a 3 or 4 years when I can afford a nice cedar one. I have a pool so a fence has to be there. Anyway, I was told to just set them in pea gravel so I've been doing that using the beige stuff that I had left over from when I moved in. I think it's called shore gravel. I was tamping down the 4th post and realized that the post could possibly shift because the pea gravel is smooth and round. The post are tight but should I be using 3/8" bluestone instead of shore stone??
farrington135 is offline   Reply With Quote
Old 05-10-2007, 03:00 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I would say gravel under the post then just packed dirt around the sides. Concrete is not necessary, even for your permanent post. Ever see a telephone pole set in concrete?
Brik is offline   Reply With Quote
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 11:27 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 12:02 PM
Tar and Gravel Roof in Florida miamitom Roofing/Siding 2 03-04-2006 05:55 PM
