Pavilon Framing Without Angle/knee Bracing (engineering Question) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2014, 11:24 AM   #1
Rewards Points: 111
pavilon framing without angle/knee bracing (engineering question)
I am exploring ideas for a pavilion off my back deck. My favorite design ideas are the type where angle/knee bracing is not used, see below:
I'm wondering how engineers/builders typically strengthen these structures against lateral/shear load.
One way might be to anchor the columns deep within the ground in concrete bases (cantilever). This might be most effective however Im not sure I could side load these columns with rim joists supporting the deck surface. Would have to support the deck surface with independent posts/footings I suppose.
I've also seen simpson connectors which could work
Anyone have experience designing something like this?
JustinNY is offline   Reply With Quote
Shed Roof Fascia and Framing Question crhage Building & Construction 3 06-22-2011 07:54 AM
small porch framing details - question wombosi Building & Construction 0 05-04-2011 09:35 PM
question of wall framing feralfreak Building & Construction 23 04-12-2011 08:42 PM
I have a question on changing trusses, I am framing an attic room. wackerjr Building & Construction 17 01-22-2008 08:36 AM
Basement Framing Question lpcon Building & Construction 7 04-17-2007 11:18 PM
