Pavers Over Existing Pool Deck -- Help Please?! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 10:18 AM   #1
Pavers over existing pool deck -- Help Please?!
My husband and I would like to install pavers (travertine?) over our existing pool deck. I would like some words from the wise please.
1. Do you suggest this as a low maintenance idea? If not, do you have other suggestions.
2. We can lay tile, so should we be able to do this?
3. Do we treat this project the same, use mortar and grout, and seal the pavers and grout? Certainly we don't use a sand base or fill joints with sand like when you are installing on a crushed stone base?!?!?!?
4. Can you suggest an affordable source for pavers?
5. Can you suggest the best mortar, grout, and sealer for a WET area?
Thanks all!
HappyNFlorida is offline   Reply With Quote
Old 10-19-2010, 11:17 AM   #2
Rewards Points: 4,578
not a tile guy but the 1st thing springing to mind is safety as is slippery,,, would much rather see your deck concrete overlayed w/polymer-modified concrete but that's our work.
year old cedar pool deck tleeee Painting 2 06-20-2010 07:00 PM
deck roof addition to the existing roof maggiedulzaides Building & Construction 1 10-21-2009 01:07 PM
Pavers Laid over Cement deck cinemod Landscaping & Lawn Care 0 10-10-2009 08:38 AM
Pool safe on roof deck? catbird Roofing/Siding 3 05-22-2009 07:49 AM
Fire pit build over existing concrete deck - am I headed for trouble? mitchcos Building & Construction 10 04-15-2009 07:26 AM
