-   -   Pavement expansion joints .......expanding! (http://www.diychatroom.com/f19/pavement-expansion-joints-expanding-110776/)
RetiredSoldier 07-14-2011 09:13 PM
Hi all. I have some sidewalks around the house that seem to be slowly moving away from each other. The expansion joints have opened to the point that I need to fill the gaps with something to keep water from washing away the base(further washing away). The gaps range from
1 1/2" to 3". I've read online about different gap filling materials, but none seem like the right fix. I've considered using asphalt repair mix compacted with a 2x4 into the joints. Any suggestions are appreciated. Here are the pics:
https://lh3.googleusercontent.com/-g.../Pavement4.jpg https://lh3.googleusercontent.com/-0...avement111.jpg https://lh3.googleusercontent.com/-8...Pavement11.jpg
Ron6519 07-14-2011 09:52 PM
Have you had excessive rain or drought there?
Is the soil moisture sensitive as in a clay based soil?
RetiredSoldier 07-15-2011 08:46 PM
We've had periods of heavy rain and then periods of dryness. I have noticed cracks in the ground during dry periods. Could be the clay reacting to dryer than normal weather. There are gaps opening around the perimeter of the pavement.
Bud Cline 07-15-2011 09:14 PM
Don't do that, it will cause the gaps to grow even more over time.
Fill the gaps with a self-leveling flexible crack filler.
Ron6519 07-15-2011 09:30 PM
The pictures look like patio type blocks. Can they be repositioned? If they can, I would do that and then keep the soil at a consistant moisture level so they don't shift as much. If the soil is as active as you say, there aren't too many products that will stay in place without stabilizing the soil.
RetiredSoldier 07-16-2011 07:41 AM
Bud, I'm concerned that the self-leveling filler would not bridge the larger 3" or greater gaps. Even with backer rods. That's why I figured asphalt would be better. Not so?
RetiredSoldier 07-16-2011 07:47 AM
Ron, Yes. A few of the peices are blocks installed after the original pavement was done. But most of the pavement is poured slab.
When I lived in Oklahoma, we were advised to water our foundations due to ground movement. Is that the type of thing you are talking about? Should I water the pavement to keep the ground from cracking and moving the slabs?
Bud Cline 07-16-2011 12:02 PM
That's probably true but I don't see any three inch expansions in your pictures, I thought maybe the 3" mention may have been exaggerated a little.:)
Ron6519 07-16-2011 04:45 PM
Yes, don't let it get too dry. You can't really keep it from getting too wet, but heavy clay soil by nature doesn't absorb water as fast as sandy or loam soil.
You can look into talking to a soil engineer if the issue becomes a real pain.
RetiredSoldier 07-17-2011 09:20 PM
Bud, here's an accurate measure of biggest gap.
https://lh5.googleusercontent.com/-g...2/Walk_Gap.jpg
Ron6519 07-17-2011 10:07 PM
I'd try wetting the soil away from the house and see if it expanded and moved the walkway back towards the house.
Bud Cline 07-18-2011 01:12 AM
There's a good idea...see what happens before you fill anything, some of the gap may close up some.:)
