Patio Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 09:05 PM   #1
Patio Slab
We bought our home 2 years ago. It is an ICF home. The patio slab is 10'x32'x6". I've noticed that at the corner where the slab meets the house it would stay moist for about 2 months after a good rain. Well today I had a 1lb ball peen in my hand. It slips out and the ball end lands on it and punches a nice round hole in it. Seems my slab is not 6" thick but 1/8" thick and packed with some kind of !@#$ paper material over the pad material. Is this standard practice now or did I just get screwed on a new home? Any help will be appreciated.
hc84cj7 is offline   Reply With Quote
Old 04-01-2011, 11:37 PM   #2
Rewards Points: 5,336
This is not standard practice anywhere I know of.
Why did you think it was 6" to begin with? Normal thickness would be 4".
What you do depends on what's there now. Worst case is that you remove the entire slab.
Ron
Old 04-02-2011, 07:34 AM   #3
General Contractor
joasis's Avatar
A few pictures would help....so where is the moisture coming from? Also....concrete at 1/8 of an inch in thickness would not support any weight....without further details, it sounds like the patio was poured over trash left in the forms, and no, most pro's would not do this. A call to your builder may at least locate the sub that did the work.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 04-03-2011, 11:53 AM   #4
Concrete & Masonry
Rewards Points: 530
Not standard practice at all. I personally doubt the slab is actually 6", as it would be overkill IMO, but I'd also be surprised if the majority o fit was much under 4" thick as well. You can always check the thickness in another section of the slab by drilling though ii's entirety with a long 3/16" concrete bit, in a control joint of course.
jomama45 is online now   Reply With Quote
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 01:13 PM
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 12:16 PM
Patio Cover on a 4" slab - HELP KrazyFish Building & Construction 3 03-30-2011 10:32 AM
Flagstone patio - concrete slab or no? txpatioslab Building & Construction 5 04-14-2010 11:41 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
