-   -   Patio Screen Door adjustment (http://www.diychatroom.com/f19/patio-screen-door-adjustment-2582/)
econdave 05-26-2006 11:57 AM
can you tell me the proper way to adjust a sliding screen door on a pation door. I know there are screws to make adjustment, cant seem to get a smooth slide. thanks
Jonny Homefixer 05-27-2006 11:41 AM
It sounds like your door is coming off the track at the bottom.
First the few obvious things that you may or may not have already checked.
1. Make sure the track that the wheels roll on is clean and free of
dirt. If the track is dented or banged up your door won't roll as easy.
3.While it may look like your door is installed correctly on the track, visually inspect that both wheels actually are on the track. One wheel may be off track.
2. Make sure the wheels are adjusted up high enough to prevent the bottom of the door from dragging on the track. Use those adjustment screws to bring the door up as high as possible. This will load the spring brackets that hold the wheels and help keep your door on track.
You didn't say whether your door was old or new but if none of these
things help you, take the door off by lowering the wheels all the way, then lift the door up as high as possible and tilt it out at the bottom and remove.
Check to make sure that both wheels are in good shape and clean,
these wheels are plastic and can break. You can get replacements
at your local home center. They are ususally just held in with 1 or 2 screws.
Good Luck
Darylh 05-27-2006 11:44 AM
I take the unit out and blow the wheels out with air and then spray a little WD-40. I then clean the door tracks so there sqqeeky clean and apply a small amount of wax. Then i reinstall the door so it slides nicely. If you turn the screw clockwise it raises the door and vise versa.
Alan 05-30-2006 02:17 PM
Also, be careful not to strip the screw or you're screwed! :D :p
