Old 09-22-2008, 11:39 AM   #1
Default Patio roof to house attachment question
Hello. Great site with lots of great info.
I am an amateur carpenter with some experience in framing, decks, and roofing.
I am planning to install a 10' x 32' back patio cover on my house. It will have 4x4 uprights, 2x6 header, 2x8 ledger, 2x6 frame, and a preferably a tin roof.
I am pondering how to attach it to the house. The house has a hip roof. The lower edge of the facia board at the house is 7' from the slab.
Option 1 and the one I prefer is pulling off the facia board, installing a 2x8 ledger board using one 3/8 x 6" lag bolt through the ledger and into the ends of each of the house rafter boards. I would then butt the 2x6 patio rafters into the ledger with joist hangers. I would also butt the patio rafters into the 2x6 header at the outside end of the patio with joist hangers. This would give me 7' of headroom at the the house, and 6'6" of headroom at the outside end if I drop the roof 6" for runoff.
The small bump in areas where the roof line is recessed would be framed in behind the ledger and plywood and shingles will cover them, extending the existing shingled roof to the ledger.
I would tar paper over the joint where the ledger meets the house, and then use flashing under the last row of house shingles and extend the flashing either 12" or 18" out over the patio tin roof.
We get quite a bit of rain here, but no snow.
I realize other option is going up and tieing into the house roof, using plywood sheathing, tar paper and then shingle the patio roof.
I would rather use the tin roof option. In your collective experienced opinions, is my plan workable or is it a complete mess?
Do you have any suggestions
Thanks for any help.
Mike
patio-roof-house-attachment-question-patioroof1.jpg   patio-roof-house-attachment-question-patioroof2.jpg   patio-roof-house-attachment-question-patioroof3.jpg   patio-roof-house-attachment-question-patioroof4.jpg
mikemobile is offline   Reply With Quote
Old 09-30-2008, 09:51 AM   #2
What's the purpose of the patio? Keeping rain off your trailer, covered work area, dining, etc?
Personally, I'd go with option 2. More astetically pleasing build without the noise of rain plinking on a tin-roof while using the patio (cookout goes undercover during rainstorm - very loud). Saves you from framing/shingling around bump-outs, no seam from shingles to tin either.
I just ripped down a fiberglass porch from my house that was almost the same set-up as you speak. Now building new porch tied to roof.
usmcstormvet is offline   Reply With Quote
More On This Topic
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
On behalf of expert village, my name is Gregg Tauriello. I'm from suite 16 studio. I'm here to talk to you about soundproofing your recording studio. On this building I have T-111 siding on the outside, which is a standard cardboard siding that you will... Read More »
Tin roofs have been around for centuries. The tin roof at Monticello, Jefferson's home, is still in good condition, despite being the one originally placed on the house when it was first built in the 1800s. Occasionally, it is necessary to pop one or... Read More »
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
Porch roof tie in question dabensys Carpentry 6 08-11-2008 04:46 PM
steel roof question kindrngentlr13 Roofing 5 06-18-2008 01:29 PM
flat roof question sflamedic Roofing 4 04-29-2008 01:41 AM
roof leak question joshm Roofing 23 04-05-2008 12:44 AM
Torch Roof Replacement Question Chad262 Roofing 6 09-21-2005 09:29 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
