Old 06-01-2009, 05:43 PM   #1
Patio Roof Beam Span
I'm adding a patio roof off of the back of my house. It will run the length of the house (58'). I'm going to run a beam parallel with the house and span the rafters 10'-12'/24"oc off of the house and rest them on this beam. I'll have 6 posts with 2 - 12' spans, 2 - 9' spans, and a 16' span. All post will be 4x6 Doug. Fir except for the 2 on either side of the 16' span - they'll be 6x6 Doug. Fir. The roofing will be the metal roof and the pitch will be 2/12 with snow load possible in the winter.
Will a 5 1/8 x 9 GluLam beam be sufficient for the 16' span? And are the 4x6 Doug Fir posts sufficient for the load between the 12' spans?. If I went with a 1/12 pitch would I need to beef up the 16' beam?
Thanks is advance.
slakfu is offline   Reply With Quote
Old 06-01-2009, 08:00 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I personally think that the 16' span is to great for a 9-1/2 glue lamb. it wont snap but it will sag over time with a big snow load. I would go with three 1-3/4" x 9-1/2" LVL's with two 1/4" plates this would be good for a 40 psf live load and 15 psf dead load, 115% Snow. if my memory serves me right.
you will most likely need a permit for this and a set of plans, which will have all this spelled out for you.
Old 06-02-2009, 11:39 AM   #3
Instead of that LVL setup could I still use glulam, but 5 1/8 x 10 1/2 instead? I've heard that glulam holds up better outdoors than LVL.
Old 06-02-2009, 04:58 PM   #4
buletbob's Avatar
I would consult with a structural engineer. I was thinking it was going to be enclosed with koma board. as I have done in the past.
Old 06-03-2009, 11:45 PM   #5
Extreme DIY Homeowner
Scuba_Dave's Avatar
It would help if you post where you are located
Snow loads vary
Scuba_Dave is online now   Reply With Quote
More On This Topic
In order to make your patio really seem like a part of your house rather just an area outside, you should connect the overhead to the house. Doing so will let you go onto the patio without even getting wet while it's raining. Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
Learn tips on how to write 'roof beam' with the Chinese Radical of wood in this free video clip on Chinese characters and foreign languages. Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Fiber cement fascia boards provide the same water protection as other materials but offer increased options for finishes. Since fiber cement tends to be more expensive than other types of fascia, you need to take greater care when you install it. Read More »
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
open span under hipped roof..... SickPuppy Carpentry 3 06-06-2008 12:24 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
