Patio Pillar - HELP - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2013, 08:56 AM   #1
Rewards Points: 254
Patio Pillar - HELP
I will try and make this short and to the point. We had a house for and had our home rebuilt. They added a covered patio in the back for us and we were very excited. A year later the patio started to sink where the pillars were due to the weight. I dug and jacked it back up and it was looking good. A year went by and we had a very hot summer here in TX and the clay ground shifted even with us watering. Now the force of the covered patio and the dry ground is pushing away the 4 inch thick cement pad ( which was never anchored to the house). I have a 2 inch space between the house and the patio cement. I was going to put pavers on top so that's not the issue. The pillar is being pushed out away from the house. How do I fix this? My thoughts were to add temp supports and remove the pillar, then cement cut a 1ftx1ft square where the pillar sits and dig 2-3 ft down, fill with cement and put the pillar back. This would keep the patio free of any direct pressure.
Thoughts, ideas? Attached are some pics.
Patio Pillar - HELP-163526_10101581073912240_218770692_n.jpg   Patio Pillar - HELP-20130922_145016.jpg   Patio Pillar - HELP-20130922_145005.jpg   Patio Pillar - HELP-20130922_145052.jpg
pwgsx is offline   Reply With Quote
Old 09-24-2013, 06:52 AM   #2
Rewards Points: 254
Anyone?
Old 09-24-2013, 09:34 AM   #3
Bill Kearney
Rewards Points: 1,174
I'd think actual footers for the posts would be in order. Support the roof first with a temporary setup. Remove the posts, then cut the corners out and dig down for proper footers. Pour those and reinstall the posts.
If you support the roof properly you might even be able to push the slab back toward the house with a Bobcat.
wkearney99 is offline   Reply With Quote
Old 09-24-2013, 09:36 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
I would like to help, however in almost 40 years of practice I've never had to deal with clay soil.
My only suggestion would be to involve a soils or structural engineer from you area that are familiar with situation.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-24-2013, 10:29 AM   #5
Rewards Points: 254
How deep would you dig? Everything I am reading says 2-3 ft and about 18inch square.
Old 09-24-2013, 10:57 AM   #6
cortell's Avatar
Rewards Points: 504
I'm with GBrackins on this one. An engineer is going to cost some money, but this requires an expert and I'm sure you don't want to keep revisiting this problem. If this was just a matter of the slab dropping, you might be able to get away with just pouring some oversized footers. However, the slab is moving away from the house. This horizontal movement is something you need to nip in the butt, and I don't think you'll find a reliable solution to that on the internet.
cortell is offline   Reply With Quote
Old 09-24-2013, 11:45 AM   #7
Rewards Points: 254
Would the patio cement movement not just be due to the fact that's its just a 4 inch thick cement pad floating on clay soil that now has the weight of the covering on the corners with no support under it? I really can care less about the cement floor right now, I just want the pillars supported- kinda tight on cash.
Old 09-24-2013, 01:24 PM   #8
cortell's Avatar
Rewards Points: 504
I would not expect point loads on the outer corners of a slab to produce a horizontal shift of the slab. Then again, I'm no soil expert. What I do know is that if it has shifted already, there's good reason to worry it may continue shifting. You may not care about the slab itself, but continued slab shifting may compromise any column-support solution you come up with. $300-$500 to get an engineer's advice is money well spent, if you ask me. But if you don't mind potentially wasting a lot of time, go ahead and crack open the slab around the column bases, pour some new footings, re-set the posts, and cross your fingers. Just make sure you shore things up properly first.
Old 09-24-2013, 04:47 PM   #9
Oso954's Avatar
Rewards Points: 1,040
I would say so. My house, driveway and other concrete are over 45 years old, and they are still shifting on the clay. Once a year when it gets wet, and another time when the clay dries out. Most of it is back and forth, but sometimes you get some unexpected travel.
I would like to know how those posts are fastened to the slab, or if they are not. It looks to me like the bottom of the post has moved in relationship to the slab.
For a immediate cheap fix, I would reset the posts plumb and use simpson post bases attached to the slab. Then watch what happens. IF your movement settles down to a liveable level, you won't need to do anything else. IF not, you can go for the more expensive fix next time.
I can't see any reinforcing ties at the top of the post. If they are not there, I would add those as well.
Oso954 is online now   Reply With Quote
Old 09-25-2013, 08:52 AM   #10
Rewards Points: 254
I removed the bottom trim and its sitting on a metal base with 2 blue screws into the cement and 4 screws up top.
Patio Pillar - HELP-20130924_182206.jpg   Patio Pillar - HELP-20130924_182215.jpg   Patio Pillar - HELP-20130924_182256.jpg
Old 09-25-2013, 09:58 AM   #11
"You can do anything"-Mom
brockmiera's Avatar
Its my opinion that if you were to support your deck, demo that corner say 2'x2' section, excavate down past the clay and pour a steel reinforced footer that not only would you adequately support the deck but you would create resistance in both x and y direction and keep your slab from moving any further.
brockmiera is offline   Reply With Quote
The Following User Says Thank You to brockmiera For This Useful Post:
pwgsx (09-25-2013)
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 02:35 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
