Patio And Patio Cover - Newbie - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 09:49 AM   #1
Patio and patio cover - newbie
Hello All,
I am in process of designing my new patio / patio cover. I have searched the internet for a while to get the answer to my questions. I would like members profesional opinion on my project to make sure I am not missing anything.
So here is its.
I am getting concrete (stamped) patio which is 32 x 11 ft.
There will be 3 footing under the "slab" which are 12x12x16 in for 3 posts (4x4)
The span between posts will be 16 ft oc and I am planning to use 2x10x16 double as a header. The rafter will be 2x8x12 space every 16in.
I was planning to use 2x10 as a ledger. Here is my main concern. I was planning to attached the ledger using 1/2in bolts to the studs. I have a hardy plank sidings which I am planning to remove (the section where the ledger will be attached. I willl make sure there is flashing installed too.
I am ggeting mix answers from the internet about attaching ledger to the studs.
I was planning to attached pics but do not know how (yet). Additionally, I have not access from inside the house (unless I remove the drywall which I am trying to avoid).
If I figure how to attach pics I will update the post.
Thank you for your help and sorry for grammatical errors.
Ski
mariuszw is offline   Reply With Quote
Old 05-10-2011, 11:22 AM   #2
Hopefully the pics were uploaded. The napkin sketch is what the patio woilllook like, the pic of the frame room is front porch cover that I want to copy for my back porch patio cover.
Patio and patio cover - newbie-back-porch-idea.jpg   Patio and patio cover - newbie-dscf1234_small.jpg
Old 05-10-2011, 11:51 AM   #3
Rewards Points: 5,336
Do you live in a temperate climate? No snow load? Pitch of roof?
Ron
Old 05-10-2011, 11:57 AM   #4
I live in Atlanta, we don't get snow (much). The pitch of the roof is same as front porch (I believe its 4/12)
Old 06-19-2011, 07:33 AM   #5
Marius, what did you find out about attaching the ledger to the studs?
crhage is offline   Reply With Quote
Old 06-19-2011, 10:41 AM   #6
crhage,
I talked to Cobb Co. (Marrieta, GA) inspector and I was told that there is no building code (at least here) on how to attached ledger to the house. He said I can do whatever I want. So my plan is to attach the ledger to the studs.
Old 06-19-2011, 11:39 AM   #7
Thanks Marius. I hope I'm that lucky. I'll be calling the inspector tomorrow.
Tags
patio cover
corner patio cover in valley dalejulia Building & Construction 2 07-06-2012 11:59 AM
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 11:16 AM
Patio Cover on a 4" slab - HELP KrazyFish Building & Construction 3 03-30-2011 09:32 AM
Patio cover Jackhammer Building & Construction 3 07-10-2007 03:49 PM
