Patio Drainage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2014, 12:54 PM   #1
Rewards Points: 83
Patio drainage
I have a house in Florida, and I have a screened in patio area, but no drainage if I want to clean the patio area with a hose. The water wants to drain away from the house, but the aluminum bars stop the water from leaving, the water will just sit there for days until it evaporates away. Can I drill holes through that aluminum, or maybe under the white aluminum and make drainage holes through the concrete floor maybe. Just looking for ideas since I like to spray down the area once a month to get the pollen and dirt out.
streetneons is offline   Reply With Quote
Old 02-24-2014, 12:55 PM   #2
Rewards Points: 83
http://s67.photobucket.com/user/STRE...tml?sort=3&o=1
Old 02-24-2014, 01:06 PM   #3
Rewards Points: 4,578
howzabout using a squeegee & pushing it out the door instead after you brush-broom patio w/detergent-bleach solution ?
you probably won't affect the structural integrity by drilling drain holes in the right spots however dirt will fall out of suspension & lie along the alum btm chord
Old 02-24-2014, 01:44 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 992
Ayuh,.... Ants, 'n other critters will use those holes, as doorways too,...
Old 02-24-2014, 05:17 PM   #5
DL's husband's Avatar
I wouldn't recommend drill holes in anything. If you drill them in the bottoms of the aluminum base - they're hollow and the water is going to get into them
I like the idea of the broom and squeeqee. Another option is to use a wet/dry shop vac to get the residual water up.
DL's husband is offline   Reply With Quote
The Following User Says Thank You to DL's husband For This Useful Post:
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
Patio Drainage (PVC vs PE vs Schedule 40) BrandonC_1972 Landscaping & Lawn Care 1 06-18-2012 09:02 AM
Drainage needs for paver patio RoRoSF Landscaping & Lawn Care 1 05-03-2012 11:06 AM
Concrete Patio drainage issues kozmo99 Building & Construction 3 06-20-2010 09:49 AM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 05:27 AM
