Patio Doors/prefab Houses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 01:58 PM   #1
Patio doors/prefab houses
Hi,
Can i install patio doors by taking out an existing window and cutting the lower section out with my disc-cutter?? Can i drill and secure the frame, and is it pretty much the same as cutting out brickwork or will it compomise any stability?
Cheers
Darren
darren75 is offline   Reply With Quote
Old 07-18-2010, 02:40 PM   #2
Rewards Points: 582
What is the construction of the house, PRC for example? Have you got a photo?
stuart45 is offline   Reply With Quote
Old 07-19-2010, 03:48 PM   #3
patio doors
Hi stuart,
I think i have attached a pic, let me know if i've not. Does PRC mean prefabricated rough cast?? the house is 50's or 60's.
Cheers
Darren
Old 07-19-2010, 04:52 PM   #4
Rewards Points: 582
Hi Darren,
PRC stands for precast re-inforced concrete. Is this house is in the UK?
There were literally hundreds of different types of system built houses thown up just after the war. Yours looks a bit like a Wates house, but it is difficult to be sure from the photo. It's probably an ex council house, so they will be able to help you.
You need to find out the type of construction to determine the best way to do the job. Replacing windows and doors is notifiable work to Building Control now unless carried out by a FENSA or similar registered firm.
The Following User Says Thank You to stuart45 For This Useful Post:
darren75 (07-20-2010)
Old 07-19-2010, 07:10 PM   #5
Registered User
Rewards Points: 5,520
May want to first check the rough opening height of your window as it appears to be 4"-5" shorter than your door......
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 07-20-2010, 01:58 PM   #6
patio doors
Cheers guys, Its an ex-council house so i will get in a professional!
Thanks again
Darren
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 02:35 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 01:41 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
